. But still I don't go out to do skids.. I polish and buff it. And drive it carefully because I can't afford to repair it.
Made my self cry... :'(
Ouch man,, hate when things like this happen. =(
  • Like 1
Got the toe sorted; front was 0 now 3mm in, back left was 3mm in, back right 1mm in, now 0-0.
Camber next; front is 0-0 rear is -0.4 L, -0.7 R. going to -1.5 front and -1 rear.
Youtube taught me this trick..... get a bucket full of water, clear tubing, tape the tubing to a ruler, suck the water into the tubing to measure the relative height of where the wheels go with the water level, then level them off with hard vynil tiles.
post-89755-0-59175400-1385118956_thumb.jpg post-89755-0-98338300-1385118984_thumb.jpg
Perfectly level to the mm. A stringline carefully set up to measure toe. A handy tool from Aldi for camber (way cheaper than a camber gauge).
And get a pro to do the job.... :D
post-89755-0-41381200-1385119030_thumb.jpg post-89755-0-86819900-1385119069_thumb.jpg post-89755-0-91255500-1385119090_thumb.jpg
  • Like 2
\m/ Anthrax Rocks! \m/
I hope you pay that Pro well Mik. That's a fine job indeed.
That's just crazy stuff that I never would've even considered. :laugh:
Cool.
Aaahhhh.. im not that clever as it turn out. >_<
I forgot that when i change camber it will change toe a little, and the adjustable upper arms on the front are well tucked up in there. Impossible to get at.
So jack it up, take the wheel off, adjust, wheel on, back down, measure, back up, wheel off..... etc
Anyway ill get there eventually, at least the rear is easy to get to.
Finally!.... fiddly sht sorted.
Got the front arms all the way in and can only get -1.2 degrees camber. 3mm toe in.
Back is at -0.9 camber. 0 toe.
Edited by D.I.Y. Mik
Put $20 of Fuel in, Checked Tyre Pressure, Washed it, Checked Radiator, Oils, Air Filter, Removed Hub Caps and Rego Sticker.
On What Car?
This.
Bought it! :D
Love it.
  • Like 2
On What Car?
This.
Bought it! :D
Love it.
Aha! Awesome! :yes:
So which one is the track car?
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
