Thrill seeker right there. ^^^ :D
3 Cars:
2010 K13 Micra ST
1996 R33 Sedan GTS25t
1989 R31 SkyWagon GXE
Put a different Horn in the wagon, a little deeper tone than stock.
Bolted in the washer bottle properly.
Tightened the overflow bottle bolts.
cleaned the car, then it rained, so its dirty...
tomorrow getting sand paper to start sanding the rocker covers
then I set up the camera at 1:00am and set the exposure to 3.5 mins..
looks alright :)
Edited by ..::R33GTS-T::..
Started sanding the flakey paint and stone chips off the bonnet. Should get primer on tomorrow and maybe a coat of paint.
Thought I should tidy it up a bit for Fridays cruise
I'd love too, that thought did cross my mind, but wasn't sure if you we're using it or willing to lend it (and to a newb, that you haven't met).
It would also help me to decide what colour to paint mine, white or black.
Yea the GTR is white. The nicest bit of the car will be your bonnet lol
Sooo if your offer stands I will take you up on it thanks mate :)
No worries - just no damage ta.
I'll turn my messaging on soon and PM you
I work from home on Fridays :) we can fit it up then (10 mins)
Edit: Go Panda Spec (white & black) - lol
Edited by Sinista32
I brake it I buy it plus compensation yea? Lol I'll be guarding it with my life :)
Sweet. I'm usually finished by 1or 2 on a Friday so that will work well.
Maybe you Jimmy and I can roll out there together? If the timing suits?
I think it'll look sweet. White and black are friends, only wish my wheels or centres where also black
  • Like 1
It would work well Rob
Can we put Sherriff badges on the front doors :woot:
I have professional black paint for the bumpers/side strips
Edited by Sinista32
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
