Yeah it's weird, permanently sticky like chewy. No wonder it dropped with a bit of heat.
Just lucky I wasn't parked on the gravel or a harder surface. (or Driving)
Might have to do both mirrors as the passenger side has always had a little bit of white goo exposed too.
Is it true that at Compliance the mirrors get changed from concave to flat glass?
Dodgy Compliance Glue!
Wankers.
looks like the stuff used inside the doors for the clear plastic dust covers
that stuff is always gooey.
Personally I'd use a good Wurth double sided tape (auto)
oem replacement glass uses double sided tape
Its horrible!
Like real soft wet chewing gum. :yucky:
Find some guys cladding an office building and get some of that tape, holy sht its good.
Bunnings have a Sikaflex assembly adhesive, black, nasty and messy, real good at sticking. Flexible, so it wont crack.
Problem is its expensive and once opened it goes off over a few weeks, no matter how well you seal it.
I have a now solid tube of it in the shed. :rolleyes: Original battery tray, i glued with that, needed a prybar to get it off.
  • Like 1
was working on a mates S14 which has been off road for more then 2 years due to defect.
nothing wrong just wide body kit and way to low so getting it ready for inspection but the coilovers are jammed.
Does anyone has a s14 coilovers or Stock absorbers to get rego passed or he can buy it
Dafuq? Are you serious? :O
Yup
Ouch! Imagine there's not many k's on that motor.
Fingers crossed for a better outcome but yeah I'd be worried about where the oil went :(
about 7000km on it. :/
will find out anyway.
Unreal... how very depressing.
Were you trying to do a 4 wheel Power Skid from Goulburn to Tuggers or something?
Damn Shit luck mate.
I was sitting at 110 in 5th the entire way back from wakie...
Anfanee drove like a granny all the way. I had planned to stay behind Anthony but couldn't. My nanna drives faster ... (RIP nanna)
In fact no-one topped 120kmph on the way there, 98% round the 110kmph mark.
da big police presence on the way out of ACT stuck in my mind and I didn't hit over 120 there and back.
(I lie - only once did I go over that and got covered in fuel by the EVO :P )
Edited by Sinista32
  • Like 1
Arnt you lucky I got it on the go pro!!! haha lol
oh and the squirt on the highway Richard.
And i got covered in fuel by the Evo and the GTR infront of me.
Yeah bloody cars haha.
Was a good day.
caught on camera - Blackmail !
I cant even trade for the vids of your Ex anymore :ph34r:
- btw: which way did you guys go. Didn't see you on the way back from Wakie
Edited by Sinista32
lol funny man. We went back via Tarago to Queanbeyan! We both like that way.
Unfortunate anf
Covered by warrenty?
Yep 100%. Just means ill be without my car for a while. Though that might be a good thing ill stop spending moneys on it so i can save for the next 6 months. Though in saying that ill be getting additional work done ontop of fixing the issue. So more money spent :/
  • Like 1
    • Next, remove the upper and lower radiator hoses, both are held with a spring clamp. While you are under there, tackle the Auto Trans cooler lines.  Again both are held on with spring clamps, and as mentioned above you should cap them on the radiator side with an 8mm cap, and on the car side loop them with a length of 8mm pipe - this will stop you losing a dangerous amount of AT fluid during the rest of the job If you've been meaning to add a sender for AT trans temp, this is a great time to do it; put a sender fitting into the passenger side line as that is the inlet to the cooler/radiator.
    • Next you need to remove the intake duct (as with pretty much every job on these cars), it is a series of clips you gently remove with a flat bladed screwdriver. They do get brittle with time and can break, and I have not found a decent quality aftermarket one that fits (they are all too soft or flimsy and don't last either) but the nissan ones are a couple of bucks each (ouch).  Once the clips are off (either 8 or 10, I didn't check) you lift the intake duct out and will see the reservoirs Undo the line into the radiator side cap (some bent needle nosed piers are awesome for spring clamps) and then remove the 4x 10m nuts that hold both in place.  I didn't get these pics, but remove the line under the radiator reservoir (spring clamp again) then remove that reservoir. Then you can get at the intake reservoir, same thing, spring clamp underneath then remove it. BTW This is a great time to put in a larger (+70%) combined reservoir that AMS makes..... https://www.amsperformance.com/product/q50-q60-red-alpha-coolant-expansion-tank/ They also make an Infiniti branded and part# version if that is your thing
    • To drain the Intake Heat Exchanger, there is a crappy drain plug in front of the driver's side front tyre: You should use the largest headed phillips screwdriver you had, and in my case I needed vice grips on the hose above as the plug was tight (tighter than it needed to be, since it has an o-ring seal).  After you have a tray down and open the drain, open the intake heat exchanger reservoir cap (drivers side one) and you should get a couple of litres of coolant To get to the radiator, you need to remove the plastic engine undertray. It is held on with a series of 10mm headed bolts and some clips. For the radiator, there is another type of crappy drain (kind of like a plastic banjo bolt) and you should attach a length of hose to direct the stream of coolant per this pic (otherwise the coolant hits the rad support and goes everywhere). The drain is on the rear of the radiator on the driver's side and a bit hard to find. Put a big tray or bucket down (5l won't be enough) and slowly unscrew the fitting by hand. You only want to remove it far enough for coolant to flow, it you unscrew it right out the whole fitting and direction pipe will come off and you will get a coolant bath (yum!). Undo the radiator reservoir cap and it should empty about 8l
    • So, this shouldn't be such a mission, but there were a few tricks so I thought I'd post up a DIY for it. This was on a Q50 Red Sport but I doubt any other V37 model is very different (maybe just less steps for the intake heat exchanger hoses) I pulled the radiator out to flush it because the car was running hot at the track, but obviously the same steps apply for changing a radiator for any reason including an upgrade. If you are removing the radiator, you of course need to drain and refill, so have 5+ litres of blue coolant ready. You also need to drain the intake heat exchanger to remove the radiator so you will need a couple of litres for that as well. You will also need something to deal with the auto transmission lines, I used 2x 8mm rubber caps on the radiator side, and a short length of 8mm pipe on the car side.....unless you can block these lines quickly you will loose AT fluid and it may be enough to hurt the transmission if you don't refill it. 2 other tools that really help dealing with coolant lines and spring clamps are Bent Needle Nose pliers Hose pliers Between them they will reduce the frustration (and injury) potential by about 1000% Other than that....lets go... "First, jack up your car". Yes really, and put it safely on stands. If you are not confident doing that you need to give this job to a mechanic
    • If the forester is anything like our old 2007 GTB Liberty, I could near on run ling Long's and "rate them", as no matter what, it just hung to the road, even when abusing it in a hard launch in the wet, or throwing it at corners.
