Cleaned the 34 and put it up in the FS
If any of you or a mate is interested send em this link http://www.skylinesaustralia.com/forums/topic/445582-2001-silver-r34-gtt-series-il-rb25-det-neo-a-c-t/?p=7338178
Thanks
Richard
Sorry forgot to mention Locals get a good discount or a very good spotters fee :thumbsup:
Edited by Sinista32
Zeb I can hook you up with the aftermarket parts off my 33 ;)
Coils, ECU (don't think sin can use it), injectors and AFM.
All you need to do then is buy a SS1PU and you have yourself a working setup not needing a tune
I've already got a Haltech lined up.
but yeah depending on if I've got the cesh when you pull the injectors out....
Zeb, if youre not touching the turbo, i wouldn't bother with an ECU. No major gains especially when setting up for circuit. It would be different if you were running 14PSI at the drags, but even with a good tune, you don't want boost higher than the stock ecu can run when on the circuit, especially wakie during summer!!!
