It's all going on down south buddy !
Not sure if being dirty haha
Highly Likely. :D
Oh and Mik's Plates look Great on the New Improved Beasty.
I may have fixed the main Sputtering / Hesitation the Wagz has been doing on and off for sometime...
CAS Plug. :rolleyes: see how it goes after tweaking the terminals in the plug but I have a new one on the way.
Makes sense if it is the culprit.
  • Like 1
Im basically north cooma lol. Royalla. Funny thing is it takes me less time to get to work from here than it did from nicholls haha.
Finished dump pipe. Should sound awesome. Debating about making a side pipe with the leftover material.... or maybe another catback :)
and it looks like ?
and cost me ?
PM if that's better
Cost $160.
Its actually the cheapest option.
No extra cost for plastic or colour or slim.
It would cost more to get a new set off the shelf. Because it would be a new number, and changing the details in the system cost more than getting a new set made.
:blink: Typical.
Yeah ill pm a photo or two to you.
Its nice to have options. Those have a very clean/oem look, I like the ones with the black bit.
Change of colour on official paperwork today.
A bug shat on it, ( :O omg!) and outside air is really dusty. Still wiping fingerprints off the door everytime i get in.
Tyre black from a tyre shop re-balancing the fronts, all over the guards. It must have been the brush on stuff as there was a drip that seems to have dissolved my wax. Its like a run in the wax.
Ive gotta get over it and not worry so much. After all, its a daily driver.
  • Like 1
Aaaah! the old chop off the vents trick. Looks good but I think I like the full vent with the black better.
Yep!
I haven't decided yet. I'll leave it on for a few weeks and see how we go ;)
nice mate. I'll prolly go blek.
the rotors look like PMU with that light blue
some work recently on the 32/4
replaced windscreen with OEM, had GTR rims painted, put new RE002 treads on, painted front/rear bar,
fit new 2nd hand steering wheel and fitted new aussie wool front car seat covers
likely polish/wax it tomoz after lunch when the sun come out
should come up pretty good I'm hoping
woops. Orderd some plates white on black like Mik's and replaced the yellow fogs with clear :thumbsup:
Edited by Sinista32
Good eye Richard both pmu pads and rotors
you made of gold ?
I could only afford the pads :(
oh and are you going to enjoy the brake dust - lolz
Edited by Sinista32
She needs a good clean. New nismo floor mats and here is under the bonnet as i got her back today. Few more changes on the way. As soon as the engine cools down. Might do it tomorrow still quite unwell.
Edited by Anfanee
GTR rims look Great Richard! Got any pics of how they fill the guards?
Anf... we should call you Larry Flynt. You are publishing porn my friend. :thumbsup:
Today I swapped my old Front Shocks back into the 33 but put some Lovell Springs on instead of the NISMOs it had.
Now the rear feels like it's squishy instead of the front. Might have to take the rear NISMOs out and put the matching Lovells in.
I think the front is 20mm lower than it was which makes the rear look too high. The NISMOs were already lower than my old stockies. :laugh:
I also put some new Nolathane rear Swaybay D bushes in the Wagz. Feels nicer and tighter again! and less like it has a dislocated hip when going from 1st to 2nd whilst turning.
Lots of red and yellow here. :D
  • Like 1
Defs put the Lovells in the rear
Rim itself fits flush with the guard but the tyre bulges out a bit
If I was modifying I'd drop it down an inch or so with Lovell springs
may be out that way tomorrow morn
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
