Got some bits in the E-go Courier Post today. :) Gotta love Gumtree.
Extractors , Grill and ECU sent from Melbourne.
Supposedly the Extractors are Genuine SVD pipes, Grill is series1 or SSS? and ECU has apparently been Chipped to suit cam and port n polish.
Price was hard to resist. :D
Ordered surge tank+fittings for the cressida, some adjustable upper controls arms for the racecar and headstuds for the other gtr. Also ordered water and iac hoses for a patrol im doing a motor conversion on. Annnnnd im out of money again :/
Know your feel bro.
About to spend a solid amount @ Ultimate
Tried everything I could think of to get the broken exhaust stud out of the head but couldn't get it so I just slapped 7 new studs in, new gasket and put the SVD extractors on.
Old gasket was well past it's use by.
Recently made a shield for the pod filter too. TUPPERWARE!!! still has a label on it that says "popcorn" :laugh:
post-78856-0-43503800-1414324773_thumb.jpg post-78856-0-01958400-1414324868_thumb.jpg
also got a new pair of Driveshaft seals from Nissan.
Rang to order them as I was previously told by Nissan that they would have to be made in Japan and sent over. (3 - 4 weeks) and would cost $28.?? each.
Got them sent from W..A. in 2 days for $55 the pair. :D
Will get around to putting them in sometime...
attachicon.gifSkyHatch Post Extractors 1.JPG attachicon.gifSkyHatch Post Extractors 2.JPG
Wow that's probably the only Pod Box that has a lifetime warranty
Rob. Worthwhile finding a cover for the relays near the wiper bottle. Bit exposed.
Not sure if the fuseable links are meant to be covered or not.
The 31 is the same.
Not sure if the Tupperware warranty would apply as it's been cut. :/
The 31 is the same.
LIFE TIME WARRANTY.
You dropped it and it poped a hole in it....
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
