Balls...my nose pliers just weren't quite narrow enough to get between the leather trim on the wheel and the stock paddle to pull the holding pin out :( gonna have to wait til tomorrow. Ah well, might be something to do over lunch lol
Looks like there's room to slot the first hole a bit so it bolts up?
My GKTech one fits perfect :P
I fitted a new modified oil pump and the sump/front covers on the 1uz today. Hoping I got the cam timing right lol
Should've gone gktech!
Even if I mounted the lock bar it wouldn't help. The toe arm bolts are actually too big for the lock bar as well unfortunately
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
