I start a new job on the 24th, and car is set up for nulon nats drags on the 26th. Wakefield eventually though!
Today I got road tyres fitted, installed a EBC and set it up to run 14psi and 19psi as the scramble boost setting.
Also installed a passenger seat.
  • Like 2
good job on the steering previous page
today I put in new door locks, boot lock and will get the new ign barrel put in soon at Johns
decided to cut and use the Nismo key on my gtr32, so it deserved complete set of new locks
  • Like 1
I opened up my bonnet and heard what sounds like a exhaust leak..close the bonnet and drove to the shops lol
That makes two of us haha.. Did pretty much the same thing!
That is so cool!!
I replaced my exhaust manifold gasket because of a leak, got a new turbo gasket thanks to Shiv. Also discovered a manifold stud snapped in the head thanks to previous owners.. Tapped out and all fixed. Just to put it all back together tomorrow! :)
  • Like 2
1.5 way diff installed thank you Canberra Import Spares! Was doing figure 8s out at Harrison playing fields car park breaking in the diff when the cops showed up on reports of a skyline doing donuts.
I had a chat to them for a few minutes and they had a laugh when picked up on what I was doing - no skid marks and tyres in good condition. Told me not to have too much fun and left me to continue. Nice blokes!
  • Like 4
Dropped the rear end to swap back to an s13 subframe. Have to get cv boots replaced and the diff looked at, one of the stubs doesn't lock in.
And of course one of the driveshafts is stuck in the hub so the whole lot has to go to Craig Hall to be fixed.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
