  • Replies 106
  • 1 month later...
Hey,
im a full time bum ass student at UQ. Also work nearly every weekend at Caltex Toowong: fancy schmancy job name =  PETROLLIUM DISTRIBUTION ENGINEER  :wassup:  ....or just "servo-guy" (10pm-6am graveyards baby) so i have almost ZERO social life on weekends.  Also bit of bar work here and there....and also drive trucks in the ARMY part time (love it, great fun) always on da lookout for some tax free dollars!! NO Johnny Howard payments here people, bust my balls to get my toys. Even do a lil car importing on the side for hobby, plus all sorts of jap parts.
Haro
HAHAHAHAHAHAHAHAHAHHAHA LOVE your signature mate!!!!
I do graveyards at Caltex too (in WA), and for everyone else, his sig is entirely true!!
It'd be the best job in hte world, if it weren't for the customers (and shit pay, and stacking the drinks, and sweeping the forecourt and cleaning the pumps...)!! hhahahaha top stuff
mechanical engineer,
sit in front for the pc all day and design stuff, i.e 3D design for vehicles being used in the mining industry ,,,
can't wait to go out to some mine sites,, and see some REAL big toys!!!
I install and maintain sound systems in nightclubs/bars/restaurants basically anywhere that needs sound systems or lighting be it architectual or Effect and a little bit of plasma , projector installs even sometimes security camera systems. What ever the boss tells us to do. I also run the hire department for all of your DJ/Party/Concert lighting and sound needs.
Kinda interesting and different every day. Average pay and loss of hearing.
What is this work? of which you all speak,and,most of you seem to dislike so much
Slip sell your car buy a house.buy another one next year, repeat this process for 5 years
meantime keep your job and in 5 years you should be able to support an R34GTR
Detective with the cops, hate traffic cops wankers - so don't worry. Been doing it for 27 years and tired of it, my toy R33 GTST series 2 keeps me sane and motivated. Been a rev head for years.
SPY!!!
omg omg we are under survelleince (by god, how much of a typo did I just make)
Hide the books, stash the drugs and lock up the illegal immigrants working on the moving parts.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
