I have bought a $30 adjustable boost controller off eBay.
Iv hooked that t peice that comes in the kit between the acutator and the intake vac hose.
With the middle nipple on the tee iv ran it to the boost controller.
The boost controller has just taken the solenoids spot.
Iv turned the boost controller to negative side and I'm still getting rediculas boost results.
Iv swapped a few hoses around and the boost is still amazingly high?
Any help will do thanks alex
https://www.sau.com.au/forums/topic/415964-boost-controller-issues/
If u can't figure out a simple thing like a f@&kin boost controller u shouldn't own a turbo car! Sell it and buy a holden
Maybe you should buy a holden since your mental capacity is on par with the stereotypical bogan driver.
Anyway, on topic, throw up some pics as this would help a lot.
Never ask you for help.
Didnt expect this from a volvo driver. Take a chill pill bro.
OP, pics are your friend here.
+1
The bloke is just asking for help u f**king dickwad.
+1
+1
more info would def help here however you generally have to wind them all the way shut (off) then adjust from there. Depending on the brand/type can be a slight turn of 4 turns to get a single PSI increase
Wow, with a comment like that you must have a really big cock, cause that's what you now look like f*ckface!
From what I'm reading, sounds like you've hooked it up wrong. The stock boost controller (assuming you have a GTS-t) actually bleeds back pressure between the pressure hose to the actuator.
What you need to do is remove that OEM t piece and fit your controller between that hose as per the diagram above. then block off the hose going into the intake.
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
