  • Replies 367
See you all at Japspec Mitchell @ 10ish. Catch Southside crew at the Supercheap carpark in tuggers sqr :D @ 9.30 if your cruising with us.
Shouldnt be any where near an all dayer and as Eiji has said there will be a few more opportunities.
I urge everyone on here to swing by even if you cant stay too long.
Bring your own Camera's as there will be some nice cars.
I also expect us to be there until at least 12.
Ciao for now - see you all in the morn
Top bloke. :thumbsup:
BUT...
It was great to see you guys and your rides. Mitchell to the lake was the biggest SAU cruise ive been in.
Richard i hope shes ok and fixed easy (not likely easy though). I always love seeing your 32.
No pics from me today, uncharged camera battery. >_<
Yep - it was very gud.
Thanks for the E&B Bren and putting my lil bitch up on your hoist. Eiji , Rob and Gabe. Thanks for being pro's in the Camry department.
I would also like to thank the intelligent well spoken and very polite bogan for letting us use his ute for props (he obviously works out and could have taken us all, actually No I think either of the girls could have bitch slaped him to be totally honest) Ever notice small dogs are yappy little f**k#ers.
11 Sklylines was not bad. Southside HEAVILY represented. Anyone from northside there today ?
Wouldn't mind a few more teasers being posted if you got em, Pahleeze.
My GTR is fine thanks - it's a 32. We dont need fluids.
Dry Sump, Dry radiator - even I worked up a thirst :P
I'm certain it's just a small split in one of the hoses carrying coolant. DIdn't reach halfway on the temp gage and only lost less than a litre in total with all the stops.
Least i will getr the Nismo plenum on while the plumbing is being replaced.
Might make a short teaser film depending how I go tonight. Got plenty of footage!
Thanks everyone for showing up
Bren thanks for letting us use the workshop and for providing bacon and eggs! Will buy you a beer some day soon.
Loved the police escort down to the river we got as well. Must have been that shady looking fella Rob!
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
