starting from where I had left off the RHS body work restoration repair
all sanded down using this wonderful tool
BOSCH Orbital Sander ;)
This bit was the hardest and hard to reconstruct some of the body work with some selleys autofix - I will have to replace the RHS sill completely in the future :(
next bit.................I also removed some of the adhesive that sits between the sill so had to refill it using this ^
here is the Sikaflex applied - looks messy there but I tidied it up after it dried
here is another pic just for the hell of it.....................I also filled some of the factory gaps with Selleys autofix and sanded it down with some 1200 grit paper
so now it is all ready to be repainted
mandatory covering and drop sheets first
I thought I would experiment and use this - some Rust Guard expoxy enamel. Yeah its a topcoat but I don't really care
First coat done
2nd coat
after the paid dried I used some Dupli Color auto spray DSSB01 which is basically the Nissan Crystal white color
instantly whiter
and a final shot - I did apply a clear coat on afterwards but messed it up - so I've re-sanded everything and started again.
Will post pics up of final result soon.
  • Like 1
I also thought I would give the side skirt some TLC
dirty
cleaner
tar is a bitch to remove but all possible with some patience
mucho bettera ;)
I also got my trusty powerfile out of my toolbox................
and removed the old adhesive that was glued on and smoothed / flattened out some of the interior edges for better attachment
The rear bumper bar is really looking for the worse
Paint cracked
more cracks
and more
yeah..........needless to say it needs to be repainted
so I removed the rear bumper altogether
and started to paint strip it
this process is going to take some time.............. :dry:
Yesterday I proceeded to clean up the rear end of the car
excess exhaust residue and silt
better........
these rear number plate lights and clips are going to get a very nice clean too :yes:
will post more pics up soon
From memory, you need to remove the boot trim that runs along, from tail light from tail light, inside the boot. There are a few nuts that are near the "Skyline" logo
Got any tips at how to get the rear bumper off? Mine seems to just hang there by the top supports but I don't know where they are.
The bottom just flaps around.
Looking good Ants. Just a tip for future the best thing to remove tar off anything on your car is some prepsol/prepwash. Comes off in no time with no effort.
thanks mate. its not much for the moment but there will be some interesting pics soon enough.
Yeah, prep wash kicks ass and is what I used to remove the tar ;)
  • Like 1
They cleaned up real nice
thanks mate.
Lights are top notch anth; what was the process involved? LED's would be great as standard bulbs are "usually" rubbish.
cheers. The process is relatively straight forward
you first need
some dirty lights ;)
like these :rolleyes:
then........................
get your hands on an old tooth brush and some laundry powder and just scrub the lights with some hot water and rinse off (after you have taken the light cover off)
the results..............I applied a little bit of plastic cleaner as well just for more show ;)
there we are.
Next stop will be LED lights as yes the standards are crap. But then again these are number plates lights so being conspicuous could help out...................maybe :P
  • Like 1
Haha just a bit 'elbow grease' hey... that makes all the difference :yes: of course!
Officer... I don't know why the LED's are playing up on me I swear :whistling:
lol...................at least they will be clean ;)
What's going to be next after the LED's are done?
More restoration work perhaps :sweat: there can't be that much left...
well............yeah more restoration work.
I have some things in the pipe work which I wont mention just yet ;)
One thing is for sure is that after I have paint stripped the rear bumper I will get it painted professionally and should look a LOT better than before.
Keen to get this car running again as soon as possible.
i am very envious of your set up!!!!!
very very good work, seriously... i really respect that you just have a crack and are prepared to make some mistakes and do things yourself! great job and keep it up!
im up in QLD now so hopefully down the track (pun not intended) i see this machine at something SAU related (although im away ALOT this year for work).
Good work!
Dan
Good work!
Dan
thanks for the supporting words mate much appreciated.
I'm not afraid to get my hands dirty but sometimes wished I had more time to devote to this passion of mine.
I guess all good things take time though :)
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
