So keen to see the suspension work happen! Can't wait ants!
me too Zac. However after speaking with Gary aka sydneykid it will be a nice package for sure. But it ain't cheap so I'm in saving mode FTM but in a few weeks we will see some suspension drool ;)
Today was a big day and got lots done.
First up the rear wheel arch got some TLC
post-5053-13955677177786_thumb.jpgsmoothed out all the dodgy spot welds
post-5053-13955677657172_thumb.jpgthen I filled in the gaps with some selleys autofix to ensure no rust decides to set in
post-5053-13955678763059_thumb.jpgpretty handy stuff
Then preparation time.
I wiped the wheel arch with some prep wash to remove any dirt and grease
Then more preparation work
Got my big trusty making tape out and.....
neatly taped around the wheel and inside the wheel arch as well
Then I attached some newspaper to protect the inside from any unwanted paint spatters. I also covered the rear brakes with an old work shirt that I no longer use
Now we are ready for painting :)
I acquired this paint can from super cheap and is the recommended paint for Nissan between 1984 onwards
Nissan crystal white yeah
Next step was to get RHS N1 side-skirt back on
Photo of corrected bodywork without side-skirt just for the hell of it
I then gave the side skirt a quick wipe down from all the dust it had gathered the past few months and then applied som Sikaflex
Next I gently made sure I put the side skirt back to where it belongs
On the car ;)
Again I used clamps to ensure the side skirt sits flush against the car
The excess Sikaflex will eventually just be peeled of after it's dried
Like so
The car is finally starting to come back together
  • Like 1
I also thought I would take the opportunity to follow a trend happening with some builds FTM
and detail the inner door cards with
CARBON VINYL WRAP!
Do first up
Clean you're door card as it has collected a fair bit of dust over its time
Then unscrew the back of the inner door pocket
Make sure you don't remove the factory glue at the bottom of the inner door pocket card
I got hold of some 3M carbon vinyl wrap from eBay for about $36 but you.can get it from super cheap about the same price the length I got it for
Then just measure and apply carefully
You do not need to cover the entire infer door card as the edges are not visible with the inner door card
I also wrapped the side open edge for more strength but is not mandatory
Then just bolt everything back up and admire you're work
That's it for now.....more to follow soon :)
  • Like 1
Lookin good mate, seeing how good yours has come up is encouraging me to clean mine up, so thanks :)
Also another door card win. Definitely a cool craze happening ATM, I will be doing this too lol
Just few more pics of before after bodywork / body kit correction just the hell of it
Thanks for putting up how you did your side skirts. Give me a much better idea how to do mine, come time!
Fantastic work.
Looks so much better!
  • Like 1
Fantastic work.
No worries Shivam. That is what its all about ;)
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
    • This coupled with 6-9 speed autos with ridiculously short gearing is why these modern shitbox cars always seem so fast off the line. If it wasn't for those things, Raptors would not seem fast. The problem we have is there is a driveability gap between a more gentle take off and a wheelspinning sideways launch. The difference between ankle flex required to achieve one and ankle flex required to achieve the other is about 0.5°.
    • Yeah I think I'm also with the opposite here. It's 'hard to keep up with traffic' because in the real world I'm accelerating with 15% throttle and they are pinning it. It feels like I'm being an overt dickhead at anything above 15% throttle, so the car sounds like I'm being an overt dickhead to keep up with/get ahead of traffic when I'm really just trying to drive with traffic. There would be no issue 'keeping up with traffic' if we used the same level of throttle input/aggression to drive around. People really do just drive around with their foot nearly pinned in econoboxes.
    • To be fair it's the other way around. 300kw is boring in a modern Golf or BMW. They are so competent / well-engineered / devoid of emotion that you have to go stupid fast to feel anything. Whereas the <300kw RB still makes all the right noises and it feels good to drive. Can pull off at the lights with the turbo whooshing and the blow-off pssshing and feel like the coolest kid on the block. Just don't look to the side where you'll see the bored housewifes in their shitbox Yaris/Corolla/Camry that kept up because you didn't go fast at all
    • 300kW is so boring in a Skyline, you'll get spanked by someone's mum's Golf with Alibaba pipes, and an email tune.
