Thought that Mike and I were coming down to your place tomorrow night and then drinking scotch and then going to Yattla for the cruise?
Ha! That would of been good.
Sadly I have already plans with family tomorrow
  • 1 month later...
  • 3 weeks later...
Well run in has been done (so I've been told)
As much as I want to go and get it tuned again I'm saving for suspension parts FTM as a car is only as good as it handles
I will put some minor updates soon ;)
  • Like 1
  • 1 month later...
Alright it has been quite some time since I have updated this build thread
I guess I have been enjoying it, hence why bugger all updates
but this aint true as I have in fact done a bucket load
First up........
I decided to take off the windshield water grill and see what has been lurking under there
so after taking off the mandatory wiper and bonnet bolts and removing them I got this
it wasn't pretty
so lets get all this cleaned up ;)
  • Like 1
Got my trusty garage vacuum cleaner and started sucking up all the dirt and silt lying within the under there grill
even took these little suckers out for some restoration lol
after a quick wipe with some warm water and soap and it already started to look a better
but me not being satisfied I wanted to go one step further
I removed the bolts to the wiper motors (except for the middle one so just tapped it up) and taped up everything else with plastic sheeting
next step was to apply a coat of clear where the windshield grill usually sits
results
  • Like 1
managed to clean them plugs rather well and went straight back in their home
whilst I was at it I thought I would pay some attention to the actual grill which looked rather in poor shape
After a quick wash with some sugar soap and warm water it looked like this
I glued the lip back with some Loctite Precision Super Glue Gel (highly recommend it for delicate applications)
Then I applied some Meguiars Plastx to get it to look like this
back in the engine bay - I had some broken studs to take off and rethread
after much swearing and broken drill bits I got the bastard out lol
me and drills - thank Christ I am not a dentist
Time for some rethreading
this is actually rather delicate to do and you must turn slowly then reverse slowly to get the right threading technique but I managed very well thanks to Youtube lol
new stud in place
next up the rear wing
thought I would take the rear wing off to detail it...........
lets just say that when I saw this
I knew that there was going to need more than just wax and polish
the rear wing stay brackets were fooked to say the least
totally corroded and unusable
the car without the rear wing
we will get all this cleaned up too
ta dah!
a bit of detailing done (cut and polish)
it sure does have a different appearance without the rear wing
  • Like 1
    • If you take the top half of the intake off you can unbolt the flap off the shaft and leave the shaft in there blocking the hole. Then you can remove the little vacuum canister off from under the manifold and get a spare vacuum line to run to the ECU. I can take some photos of it later. Probably best to get the vacuum source to the ECU sorted first though. Mine all worked mint with the base map from the GTT an I've pretty much let the closed loop sort the fueling and took 1 degree out of the whole timing map.
    • This IS something you also have to configure in Haltech (or at least I did in the past when going from onboard-to-ECU map sensor and an external MAP sensor in haltech land).
    • I'm hoping it's something as simple as the ECU is looking for an external MAP sensor, but he is trying to use the onboard MAP sensor.
    • You won't need to do that if your happy to learn to tune it yourself. You 100% do not need to do that. It is not part of the learning process. It's not like driving on track and 'finding the limit by stepping over the limit'. You should not ever accidently blow up an engine and you should have setup the ECU's engine protection to save you from yourself while you are learning anyway. Plenty of us have tuned their own cars, myself included. We still come here for advice/guidance/new ideas etc.  What have you been doing so far to learn how to tune?
    • Put the ECU's MAP line in your mouth. Blow as hard as you can. You should be able to see about 10 kPa, maybe 15 kPa positive pressure. Suck on it. You should be able to generate a decent vacuum to about the same level also. Note that this is only ~2 psi either way. If the MAP is reading -5 psi all the time, ignition on, engine running or not, driving around or not, then it is severely f**ked. Also, you SHOULD NOT BE DRIVING IT WITHOUT A LOAD REFERENCE. You will break the engine. Badly.
