Selling my 1995 series 1 R33 GTS skyline non turbo, this is a great car, never missed a beat, no leaks, oil and filter changed regularly.
Great p plate car looks good, clean and fast.
ive had this car for almost a year now, and has never let me down, mechanically the car runs great, and looks good!
Rb25DE engine
5 speed manual
18inch rims
exhaust system giving her a nice loud sound
M sports style bodykit, front bar has small crack, but will come with stock front bar that has recently been resprayed.
Also will come with another hood, due to the one on at the moment has a few dints ( the car hasnt been crashed, just a second hand hood), the other hood just needs a respray.
has a sub, speakers and amp installed just unsure what the brand is.
Comes with rego until may
automatic windows
air con
aux cord hook up to the Jvc screen head unit
interior is great and tidy, cleaned regularly.
body and paint work is good no dints or major scratches, but there are a few small scratches, not really noticeable.
new battery less than a year old and new sparkplugs
This car has not be thrashed, its a clean car, just to cruise in. Tires are in good condition, plenty of trend!
The car has done around 200000kms, but the dash has been changed and says 126000kms
ive probably forgotten something but yeah thats the car :)
im asking for 7000$ price is negotiable , any question text me on 0423010610post-92673-0-94157500-1357027367_thumb.jpgpost-92673-0-26238800-1357027381_thumb.jpgpost-92673-0-43802400-1357027407_thumb.jpg
https://www.sau.com.au/forums/topic/416544-1995-r33-gts-skyline/
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
