I have 18's unsure of width but 255's look like they fit nicely so between 9-10 inch I guess. Scrubs slightly but my car is very low. Im positive that GTR's need at least +35 offset, where can I find the details for my rims? They're Enkei's but I can't find any dimension markings on them.
http://www.users.on.net/ecenshu/GTR/150/IMGP0384.JPG
