Been wondering who would do this first..haha...gold, mate has just bought a roller to do the same, looks like he has no
chance on being the fastest in the world now...
cheers
darren
Yeah sort of stuffs that plan up of mine lol, might just have to concentrate on pushing my street stag closer towards high three hundreds , hmmmm had thought of using a diffrent power plant in the future drag car, but been to busy playing around with bikes again being summer
https://www.sau.com.au/forums/topic/417305-rips-mgawot/#findComment-6704706
