Hi guys was just wondering if you guys could help. Recently got a respray and a new body kit to fit on my r32 gtst. I told him if its too low not to put the kit on and just spray the old one and il fit that one back on. I went to pick it up as I work away and I could barely get the thing out of his driveway. Now I have a car with absolutely no engine problems but can't drive it anywhere. Could u please give me some suggestions???? ie suspension job or just rip the bloody thing off?
Any help would be great
Thanks
https://www.sau.com.au/forums/topic/417313-help-with-body-kit-too-low/
What kit is it? And are you running coils? Either just raise it a bit if you are, or put the old kit back on. Or just take time to learn balance between the kit and ride height and I'm sure you'll be able to drive it. That's what happened with mine, after a whille you get used to what angles to take, where the car will and won't scrape etc.
Um it's a aftermarket one my mate got from over in the motherland. Its made buy one of his mates over there. its a really nice kit and different to any other ive seen so i sorta want to keep it. Nah not running coils yet I got a set ready but didn't know if it would raise it enough?? Nah it's not even possible to drive on at the moment. I've got about an inch under the front bar lol I had the stockies on it and couldn't even get up my driveway which is flat.
As above, raise it up a little,
I suppose the lesson to learn here is don't take someone elses opinion on what is "too low" for your car as everyone is going to have a different idea.
Same would go for an exhaust shop and telling them not to make it "too loud" if you get where im going.
Grab some higher res shots, would be good to see the full car closer, i imagine the colour would get you quite a bit of attention.
1) raising the car (as stated above) is a must
2) check rolling diameter of wheel/tyre combo with specs or a mate's gtst to see if tyre profile is correct
You know what the minimum height is off the ground don't you?
Oh yea ok then thanks for the info. The under body of the car is not low at all. When the old kit was on it it looked like a 4x4 lol I haven't been in Australia very long but the minimum height for a car in nz is 100mm is it the same here? But yea I know it was a silly move letting them estimate wether it was low or not but I work in NT and it was just way too hard to communicate with them lol I have some high res pics but it says they're always to big to put on here. If someone could help I have them on my phone
Thanks
Edited by gold32
Thanks
Judging by the tyres in the guards it has been lowered, unless the tyres are a much bigger outside diameter. In QLD it is 100mm from any point and I believe that's the case everywhere else.
Oh yea cool thanks. Yea well it was lowered a bit but I didn't have any worries about judder bars or anything. But now it's just too much lol I have to put the coilys on just to get out of the driveway. I have some but they're from my mates 32. Any suggestions on a new set? Just for a daily
    • You Gregged a whole racetrack!?
    • Look for broken wire or bad connector at the motor. Might not be it, but is worth starting there, as it is easy.
    • Hi everyone, I’m having an issue with my R32 GT-R. Sometimes, when the car goes over a bump or experiences some vibration, the 4WD warning light comes on the dashboard. When I check the code from the control unit in the trunk, it shows Code 19 – ETS Motor. However, everything seems to be working fine — if I turn off the engine and restart the car, the light goes away and everything functions normally. Has anyone experienced this before? Where should I start troubleshooting this issue? Thanks in advance!
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
    • 310mm rotors will be avilable from Australia, Japan, and probably a few other places. Nothing for the front can be put on the back.
