Wrong.
Smash camera with bricks, try to inject broken camera in arm, take bricks to tin shack, ride pit bike to cash converters, threaten cashier with mullet, takes munies then die in a stairwell of a heroin overdose.
FYP.
#drinkingattheredcow
https://www.sau.com.au/forums/topic/417327-my-pnm35/page/7/#findComment-7055493
Meh, was working. Couldn't make it. Can post?
man, we just whored this build thread.
How is the transgo shift kit, feel good Matt?
LOL! Gotta fill the thread with something!!
Great, grabs heaps hard, car feels fasts. Has made the car completely different.
Car is almost where I want it, mod wise.
Next on list:
HFC's
Uprev
Maybe V36 Y-pipe because rusty vag pipe in between stainless steel HFC's and cat back exhaust has gaids.
Then finished with grips and "performance" side.
After that will be trying to fix paint, interior, electronics.
https://www.sau.com.au/forums/topic/417327-my-pnm35/page/7/#findComment-7055517
Next on list:
HFC's
Uprev
And tighten moar bolts.
It's like the Harbour Bridge.
Sorry for whoring. I'll stop now.
https://www.sau.com.au/forums/topic/417327-my-pnm35/page/7/#findComment-7055546
  • 1 month later...
  • 1 month later...
Small update.
A Fenix radiator arrived today :D
I've also purchased, walbro 255 fuel pump, 510CC Power Enterprises injectors and an Uprev cable.
Just need Uprev MAF, Uprev tuner software, LFR6AIX-11 spark plugs and a couple more cooling bits.
Then gotta save for install, fab and tune.
https://www.sau.com.au/forums/topic/417327-my-pnm35/page/7/#findComment-7165360
  • 1 month later...
Oh I haven't updated!!
So the radiator, Scotty's cooling bypass mod and nismo thermostat were installed a couple weeks ago. mad props to PNmad for doing the work while I supervised while swimming in a pool of coolant and trans fluid :D.
Recently been worried about the stag using a bit of oil. I serviced it less than 3 to 4 months ago and on monday I checked my dip stick and spotted it on the half way mark, checked the sump and areas around it for damp and slimy areas but everything was dry.
Just today when I was changing over cam position sensors I noticed the below. Appears my spark plug well has turned into an oil well.
I have come to notice that for every thing I mod/change Rajab f**ks something else. Rajab loves it.
Edited by M35woah
https://www.sau.com.au/forums/topic/417327-my-pnm35/page/7/#findComment-7205045
Its no big deal, most of the VQ's I see have oil in the plug well. It is insulative so it doesn't affect the spark.
How long since you changed the plugs? If it's been a year or more, I would just suck the oil out with a syringe and small hose. The seals aren't replaceable so you would need to get an entire rocker cover and gasket to fix the weep. Big dorrahs.
https://www.sau.com.au/forums/topic/417327-my-pnm35/page/7/#findComment-7205082
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
