Ok, so I was giving the car a bit of abuse tonight then all of a sudden the clutch stopped working and I couldn't get into any gear. After about 10 minutes of driving the clutch starting working again, but whenever i use it there is grinding noise when it's on the friction point. No grinding noise when the pedal is fully in or out. Also the friction point is twice as big now. Clutch is a Exedy 5 puk.
https://www.sau.com.au/forums/topic/417637-clutch-grinding/
+1 to the above
sounds like you may have burnt the plates on the clutch but you will need to take the box out anyway and i would suggest replacing all fluid and you may have boiled it...
giving the info you have provided its hard to say could be more issues with the box for all we know but it depends on what you mean by "ABIT OF ABUSE"
https://www.sau.com.au/forums/topic/417637-clutch-grinding/#findComment-6704919
+1 to the above
From a standstill I reved up car and droped the clutch in 2nd with my foot on the brake, quickly changed to 3rd, sat there for 3 seconds and peeled out up the road. When the tyres gripped I tried to change to 4th and thats when this started to happen. The clutch doesn't slip.
https://www.sau.com.au/forums/topic/417637-clutch-grinding/#findComment-6705338
Yeah weird sound there
If it made it while just idling then it would be the thrust but that noise is just as it grabs.
Dropping it in 2nd puts a shit load of pressure on everything so I would suggest not doing that again dude. Only the hardcore drag racers with really quality clutches and lots of power do it
Still as I said in the end your going to have to take the gearbox out and inspect. It's to hard to diagnose over the Internet. I had trouble with my clutch and I had to bite the bullet and pull it out.
https://www.sau.com.au/forums/topic/417637-clutch-grinding/#findComment-6705416
I think the clutch welded itself to the flywheel. On the drive home I must of broke it free and the grinding noise might be from parts of clutch still welded to the flywheel or the clutch is worn to the rivets.
Edited by H4x
https://www.sau.com.au/forums/topic/417637-clutch-grinding/#findComment-6705822
It's welded it's self. You'll find little bits of brass imbedded in the flywheel.
Any brass button clutch that slips bad enough to create massive heat will try to weld it's self to the flywheel.
https://www.sau.com.au/forums/topic/417637-clutch-grinding/#findComment-6706189
Heres some pics:
Just got a few questions:
This side faces the pressure plate right? Don't see how it would spin if I put it on the other way.
No gasket goo on the front cover gasket?
What size are the nut that go on here? Turns out my car never came with them lol.
Edited by H4x
https://www.sau.com.au/forums/topic/417637-clutch-grinding/#findComment-6746325
I'm guessing you pulled it off to check the bearing?
Just put a very thin smear just to be sure. That is if the gasket is still in good condition. If it has any tears or is a bit rough get a new one, there's nothing worse than putting it all back together to find it has a leak.
https://www.sau.com.au/forums/topic/417637-clutch-grinding/#findComment-6748393
Lol i do that instead i dump it in 4th standing still.
https://www.sau.com.au/forums/topic/417637-clutch-grinding/#findComment-6752956
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
