1990 NISSAN SKYLINE GTR 32-------
-GENUINE 86,226 KM
-BAYSIDE BLUE PAINT
-TINTED WINDOWS
-HKS GT 2510 TURBOS
-APEXI POWER FC D-JETRO ECU
-EXCEDY HEAVY DUTY CLUTCH
-APEXI AIR FILTERS
-BLITZ TURBO TIMER
-GREDDY BOOST CONTROLLER
-KYB SUSPENSION
-3" HIGH FLOW EXHAUST
-MOMO STEERING WHEEL
-18" RAYS LM GT1 WHEELS WITH 265 KUHMO TYRES
-RECARO SEATS
-CLARION HEAD DECK
-JVC MOS-FET 600W AMP
-ALARM/CENTRAL LOCKING/IMMOBILISER
-------STANDARD FRONT STRUTS INCLUDED
CAR HAS BEEN SERVICED EVERY 5, OOO KM WITH MOTUL 300V SYNTHETIC OIL
--------CAR HAS LOW AND HIGH BOOST SWITCH
LOW BOOST AROUND 260KW
HIGH BOOST AROUND 320KW
$23,000
Impressed - thank you.
I know it doesn't mention it so the answer is most likely not, but has the engine been cracked open / rebuilt?
Do you have the history of this GTR ?
Edit: Ps. Detailing it well will show it up so much better.
not that im aware of mate. the engine is fine.
it got imported to syd in 05. then had another owner in SA and then i bought it in 2011.
i have all the paperwork for it
think it was painted before it was imported here. not sure what colour it was
Looks to have been the Gunmetal from the engine bay pic.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
