  • Replies 87
Also have the following:
Used N1 oil pump approx. 27xxxkms. Only removed as replaced with a nitto item. Works perfectly fine. $100ono
also have used charcoal cannister. $100ono.
Make some offers guys, im fairly easy.....
Aircon gear now sold.
Rest is still up for grabs. Open to offers people....within reason of course.
Bonnet now gone.
Still got the TE37s and a few other bits and pieces.
Like i said, im open to offers within reason.
Come on guys, chuck me some offers.
Need to clear some room in the garage.
Perfectly good set of TEs waiting for a new home.
OK ladies and gents.
Starting tonight and ending next sunday (21/4), ill take off 20% of the prices i have up here.
Thats $1600 for a set of TE37s
$800 for a rb26 head
$400 for a lightly used set of accralite forgies with standard rods (extremely light)
Motivated to move this stuff guys and girls.
No holding items, first in with cash gets it.
Aaaaaaaaaaannnnnnddddddd GO!
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
