I'm looking to buy an Apexi high flow panel air filter here in Australia, but i'm not sure where to get one. I tried both supercheap and autobarn, but they only sell k&n.
I want an apexi one because I don't have to maintain it by re-oiling it every few thousand km.
I see that nengun.com sells them at a good price including shipping, but not sure on how fast they are at shipping. Any experience with them?
cheers!
https://www.sau.com.au/forums/topic/417877-where-to-buy-apexi-air-filter/
i was looking at using EMS - International Express Mail Service. It says it'll take approximately 3-5 days after the order is sent from japan, but just want to know how reliable it is to buy from there and is the estimated shipping date accurate?
buy a 3A racing filter this out preformed all the rest of the big name brands in flow and filtration $30
not trying to put down your recommendation, but just wondering if anyone can confirm this? I've never heard of it that's why.
Also, is it a pod filter, or can you get a direct fit panel filter to fit in the stock box?
cheers for the info guys!
its a pod filter
sorry your looking for a panel
k&n work fine
Edited by WARLORD
What do you guys think of the BNC panel filters? I was recommended to get one and it seems to work great, very high flow.... On the dyno it makes very little difference if it is removed or not...
Think it was something like 250rwkw vs 254rwkw on back to back runs... Snorkle, BNC Panel and stock airbox vs no airbox lid or filter... (Open bonnet)
Thats pretty impressive. Do you have a comparison between those stats and pod filter stats? I used to run a K&N panel filter on my 33 with stock air box and intake. It was pretty good (better than Ryco etc filter) but then when I fitted a pod It felt a bit better. I think a good pod in a good ensulated enclosure is the way to go though.
Nope, I've never run a pod filter on my 33...
Also keep in mind that the close power figures could have been because there was some other restriction which was limiting the power (exhaust, intake piping, turbo, etc)
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 😉. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 😍.
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 🙏 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 😉. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 😍 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
