  • Replies 297
Well done to the winner, great job.
Have you ever competed big fella, I know you used to train at MusclePit.
WA states coming up soon
No never competed . I did some lifting/training when I was 30 , with some silly idea of getting ready to do some track and field.. Never did get round to it(track). I was only going to a regular gym that happened to have a decent lifting setup. Was training by myself at the time so learned what I could. I got pretty strong, didn't realise it at the time. I was about 80 something kilos , I can't actually remember the deadlift weights but, I was squating sets of 250kg (235 on the bar) for 5-6 rep sets. I have some pics from back then , with some heavy equipment based lifts.
Had not done any deads since then. This last deads session is only my second since then. Did some training with some friends a few years back but, no deads or squats in that program (shock horror). Got sick a few times in the in between years and lost losts of weight. Plenty of it from the legs.
To correct the confusion I worked with Henry at Xerox (we talked about the comps and training alot) but, haven't trained with him yet.Kept putting it off. Sent a few people his way and figured more recently I would make an appearence once I am ready. I believe I have lots to learn since I have never been coached on lifing properly in my view.
definately like to see if I would be any good at the comp side of things looks like fun.
Edited by rev210
see told you, set the bar high... nice lifting
seriously though WTF crappy bar/plates are you using!? basically doing deads from a deficit every rep due to the small diameter of the plates lol... you could've propped them up on something
Ha ha... yes gheto weights. It's not so bad if I have to travel a bit further in the ROM I suppose, it's all about giving my back a good workout.
I think I irritate the missus as I am pinching all the weights to stick on the bar and then forgeting to put them all back. I think she is keen for me to go to the gym ha ha..
Edited by rev210
Well I reckon you can now set the next challenge mate.
Start a new thread with the next forum challenge.
Your choice.
Look at the results from this thread and make it suitable for the masses... after all it is to get everyone in to the spirit of friendly competition and to push themselves.
Also, PTC Perth hold Novice comps that you could go and try your hand at to get the bite which you will no doubt get to start PL again.
Your choice.
It's still possible for someone to do 28+ today. Come on people , you can't let the almost 40 dude win.
Yeah the PTC is in Malaga which is much closer than Muscle Pit. I am thinking that might be a good place to go.
I really want to learn the techniques to lift right and address the strength imbalances I have. Its more important for me to get that right before training hardcore for strength or comps. I believe that the efficiency of lifting right is actually a great way to safeguard the body for the long term and thats what I am after.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
