Guys ,
I just replaced my alpine speakers in the rear after hearing crackles when pumped up finding the cone had a split in it but since doing that i am now getting an alternator noise which is pissing me off.
Does the atlernator have a condensor on it anymore or are they internal?
Would putting a filter accross the amp (in boot) or headunit work and which one?
I have put my cd on and it still comes through and even not starting the car i can even hear a slightly softened whire which i thought was my amp fan but it may not be..
any ideas would be greatly appreciated
Dazza
https://www.sau.com.au/forums/topic/418053-alternator-whine-through-speakers/
I'm not to sure about that. But I know I get a small noise through my speakers when I turn lights on etc, its nothing worth worrying about cause you can only notice it when theres nothing playing out of the speakers. Maybe its just something to do with the speakers, From memory the LH rear speaker sits pretty close the the battery terminals (depending on speaker) so maybe your new speakers sit a bit closer then the old ones and this is causing it? Not sure what new speakers you have but if they are the exact same speakers then that would be a bit more confusing.
Guys ,
Dazza
Car not started and it whines isnt alternator !!
the wires are touching something or pinched
A cooling fan on amp
Can be amp, or radio and you didnt hear it before
Rca's creating inductive noise whine , power cables too close to rca's
rare but speaker wires to close to hi current or switching relay in boot
Bad cap on tweeters can do it but not common
For the other persons problem
A little whine can mean alternator ripple going up
= alternator is dying / battery or wiring issues
Edited by Carbon 34
  • 3 weeks later...
If you have a friend with spare speakers lying around, chuck them in for a day to see if it still does it. It might just be a crap set of speakers. Every manufacturer can have faulty gear from time to time. Most modern electronic gear will either fail in the first 2 weeks, or go for more than 2 years no problems. I hope this helps.
Hmmm no that wouldnt fix it in most cases
Hi There,
Often engine noise can be a few different things a few things to check are:
1. RCA- Use good quality shield type and keep away from the amp power cable and also the vehicles main power looms.
2. Amplifier- Gain on amplifier too high. Often people put the gain too high and this will cause excessive engine noise.
3. Cheap Amplifier- Try using a good quality amplifier or a digital amplifer often will work better then the cheaper ones.
Check these things out.
If all else fails you can use an inline RCA noise filter but these aren't the correct way to fix it and often don't always work. If you do want to try them they are about $15 generally and will plug inline with the RCA's simple fitment.
Hope this helps.
Daniel Gardener
Carbon Car Systems
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
