Soo I bought a reputable brand clutch 400kw single plate less than 3 months ago & had it fitted by a reccomended workshop on this forum, all was fine untill the other night.
Went to change gears and peddle went straight to the floor & couldn't select any gear, got under the car and inspected and found that the throw out bearing had separated from the pressure plate, is this a common problem with pull type clutches? What would usually cause this failure? Just asking for opinions.
Spoke to the clutch manufacturer and the said the see this issue a fair bit and that it's cause by ppl letting the transmission hang from the clutch during re installation. The asked me to take it in to them so they can inspect it,
Hopefully they will warrant it as I don't want to spend another $1600 on a clutch for it to fail again.
If it is the installers fault then I hsve fat chance of them covering it as they seem to have closed their business
https://www.sau.com.au/forums/topic/418076-r33-gtr-pull-type-clutch-failure/
Not good mate.
even hanging the box, I wouldn't expect this.
generally, you put the box up, then engage the bearing.
its pops in, but can't come out.
unless the clutch had it in to begin with, not many do.
keep us updated.
obviously it shouldn't pop out, but maybe the clip was damaged on install? will be obvious when inspected.
you could try unbolting the slave and see if the bearing clips back in? but if it is damaged it will probably pop out again.
Got the box out over the weekend, problem was as expected, the circlip the retains the throw out bearing was in 2 pieces and bent as a mofo. Took it all to the clutch shop, they replaced the clip, machined the pressure plate and flywheel and repucked the clutch plate with new pucks. Right there and then, No questions asked all for $0. They even gave me a clutch aligning tool aswell.
Cannot ask for better service than that.
I just finished bolting the box up to the engine, hsve to wait on a few things from Nissan before I can get it driving again.
    • Hey everyone. Is there a way I can get the original window sticker (maroney label) for my 1995 R33 GTST? I doubt I’ll be able to ever get it but it’s worth a shot to ask
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
