  • 2 months later...
On my radio for I think it is 79.3FM it says "Radio 80", rather than just saying 79.3 again. Does anyone know how to enter text for each station, would be nice to change it to "Triple J" or "99.3" and alike for each station, if it isn't too hard to do.
(I have searched...)
  • 3 years later...
On 6/9/2013 at 9:39 AM, 30ONA said:
SO I bought another band expander this time with a power wire. Connected the power wire to the violet cable on one of the hard drive harnesses that showed 12v when ACC on. Check with multi meter and there was power to the band expander when acc on. Put it all back together and I have no radio signal at all.
Please help.
Hi,
You mention you bought another expander with a power wire.  Were you not happy with the one you got from synergy?  I'm looking at doing it soon and can only find the synergy type.
Can you tell me brand name, part number where you got it from?
Thanks
Frank
  • 3 months later...
For what its worth for any one reading this, I bit the bullet and bought the band expander from Sinergy.  It was a simple plug and play exercise and took approx 30mins or so.  I can say it works fine and where the band expander in my PM35 struggles to pick up a station, (on FM) the one in my V36 excels,  I live approx 30km from Adelaide CBD and what could be classed as in the foothills so that always played havoc in my PM35 until I started driving towards the CBD.
  • 7 months later...
HI All,
I have a 2008 V36 and purchased a radio band expander from Sinergy. Went to fit it (Jap Bose system with navigation) and it appears as if the plugs are different. Can anyone tell me whether the plugs are different for the 2008 as opposed to 2009+ models before I pull the whole radio out again :( I would also very much appreciate any further advice on whether there is a need to add the power wire to the connection; as indicated earlier in this thread. Many thanks
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
