hey all,
just after some info as i searched and gave the rb20 manual a scan.
what pressure readings should i be getting on the coolant system?
i'm using the12mm hoses up top near the intake manifold with a t-piece barb on a pressure gauge and my readings are when car is cold running.... 0 psi and 13psi when hot 70-80c unless somehow said lines are no good for readings to be taken.
blew a heater hose so i replaced hoses and a thermostat with a rb25 unit and is there ment to be a lil bit of black rubber circle ring on it near the opening( tried to see if i could remove it but seemed pretty solid so left it) as i usually just run rb30 thermostats and they dont have this ?
i know something is up as car is overheating 80c while idling, top hoses are hot and bottom are cold/normal so must be water pump or newly installed thermostat
Edited by Dan_J
https://www.sau.com.au/forums/topic/418093-water-pump-pressure-readings/
That pressure seems about right, and the 80c temps are pretty good too. What is the issue?
It's a good idea to test thermostats before you use them, dunk it in hot water and see what temp it opens...
really zero pressure when cold?
was about to start on the water pump but figured i'd confirm on pressure and the rubber ring on the new rb25 thermostat before i go to the effort
^^^^ it takes me a decent drive to get the car up to 75 normally...... and these temps are just sitting in the driveway raising quickly
EDIT it doesn't stop at 80C , turned it of at 86 as it was getting abnormally hot
Edited by Dan_J
the standard thermostat is set to open at 82 degrees. anything up to about 90, or even 95 at worst case scenario is normal on a really hot day for the original cooling system, as it gets less effecient as it gets older and gets build up in the radiator. if you had a brand new thermostat and radiator then 82 to 85 degrees is normal.
Standard water pump creates some flow not pressure. The pressure comes from the heat making the coolant want to expand. So at ambient temp it should have no pressure, when at operating temp should have whatever your radiator cap is rated at. They are 0.9bar from memory so 13 psi does sound right.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
