Hi guys my r33 gts N/A is bogging down in power in 1st and 2nd gear at about 3 to 4,500 rev mark and wont go beyond that it is only a intermittent problem .
Things done to car at service...
1 fuel fiter and all rubber lines
2 air filter high flow
3 cleaned maf meter
4 new coils and plugs
5 new 10w-40 oil and filter
6 done all vacuum hoses
engine mods...
1 full 2.5'' system
2 high flow air filter not a pod
3 bigger injectors and fuel pump
4 turbo computer to control injectors as the n/a one inst tuned to run 370cc injectors.
With those mods the car runs fine but every now and again it wont rev in the first 2 gears it seems to do it if you drive stop turn it off and start it later and it will do the bogging thing.
fixed power issue now have a dead cylinder i change the fuel injectors it started run fine and test drive was all good got home went to start it it took a minute to start then it was missing on one of the cylinders it is a constant miss a dead cylinder
3 cleaned maf meter
engine mods...
1 full 2.5'' system
Stick with the N/A computer and re-map to suit bigger injectors.
i cant get the computer remapped apparently and the bigger injectors were in stalled because i was going to bolt a turbo on but was told it will blow my engine so last nite i put it back to n/a standard but the old injectors are leaking and need new orings
running an ecu from an engine that is designed to have lower compression and a turbo bolted to it isn't going to be helping one bit. it may even be causing some serious damage to your engine, depending on what the AFR's are like.
yea lol i was going to turbo it but was told it would blow it up so i tried to see how it would go with those injectors appears no good so its all back to n/a standards but waiting on new injector orings for the stock injectors as there leaking
Who said it would blow up, running <7 psi should be fine, many people have done it infact there's a sticky in the NA section about it :/
http://www.skylinesaustralia.com/forums/topic/249186-nat-power-results-na-t-turbo-conversions-only/page__pid__6587345__st__140#entry6587345
Edited by Captain Natro
a mate of mine said who is a mechanic but has a skyline said it wouldn't work unless i run low boost like 4psi
It has to do with the compression ratio of an NA motor being higher then that of a turbo motor, resulting in a higher likely hood of detention on pump fuel even at the same boost levels. But in saying that there is power to be made from de+t ing an RB25.
Hell my mate had an old dirty thirty Natro, bolted on a ling long spec 35 and made great power for what it was, has just purchased a water meth kit for it and with more boost wound into it should see fairly decent figures...
I'm not going to say this is the best option but it definetly is one :) (just have a read through that thread you'll see)
Your mate is a complete dumbass. Its been done before, there's a dude on here running 18psi through one on 98 octane. Been going for a few years too.
this is building up confidence and i will save up for the stuff so i can convert it i need hoses intercooler oil cooler turbo piping stock turbo i have need seal or i might buy a new one pump is done an radiator is done old rad exploded one day after i got home
I'm trying to remember who it was but its not coming to mind, may of been hanaldo maybe I duno it's irrelevant.
More to the point it can be done and with quite pleasing results. What would get most people I imagine is getting greedy and continuing to wind more and more boost in, in this situation with the high comp (something like 9.5:1? Not exactly sure) it will go pop....
*cough* Read that thread first *cough* :)
I know quite a few turbo cars that run 9.5:1 comp and 20+psi on 98 octane ;) its all in the tune. Aslong as everything is kept in check it will live a long and fun life.
It could be more then that (its been a while since I cared about Natro RB motors). Tune is very important but that's like any car the tune makes or breaks the setup.
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
