Ok so I'm kinda fond of the Idlers style big lettering on the side of the tyres. What's the best way to achieve this?
I'm assuming a lot of these are stencil + rattle can jobs but surely there are other ways? Is there anyone in Oz doing something similar to http://www.tirestickers.com/ ?
Here's what I'm after (via Speedhunters):
RWB Idlers style:
Interesting idea. I'd want to know how well paint can paint lasts with the heat/cold/twisting a tyre has?
Hopefully it'd be better then those white walls people get painted on as they don't last
Well that's the problem, from what I've read basic brush + normal paint job just won't last. Some people have to repaint theirs every couple of months.
The stencil + spray idea seems easiest as it's very quick to redo. However, I can imagine it starting to look a bit messy around the edges after a few times.
Has anyone got first hand experience with stickers/decals? How well do they last?
In 1970, I used to pinch my younger sister's oil based crayons (white or yellow) and it was like 'colouring-in' hehe...
I forget, but it might have lasted a couple of months I think > Kleber tyres never looked so cool lol.
  • 1 year later...
Ok so I finally got around to trying this the other night, with some Goodyear Eagle stencils from Canada: http://www.racelinedigital.com/store/index.php?main_page=product_info&products_id=2048
The bad news is, acrylic paint definitely does not work, it's already flaking off after a couple of days...
The other bad news is, I found out that my tyres are shagged when putting them back on the car after doing this :(
The good news, I really like the look:
Any ideas on how to do this properly and which paint to use?
(I'd also love to 3D print some sidewall shaped stencils to avoid buying more sticker ones each time this needs to be redone...)
I have spent quite a lot of time trying various paint and pens and my conclusion is that it is possibly highly dependant on the tyre wall stiffness.
I use a regular pen type on a set of Falken RT615 and it lasted for 1000's of Km.
Now with a set of Bridgestone RE002 and even two different tyre wall specific paint cracked and peeled within a few 100 Km.
I just use some stuff I got from ebay for like $6 it looks like a paint touch up brush/pot that you get from supercheap or so but it ends up drying kind of rubbery, last for agesss unless you get up and close to it with a high pressure gernie lol... just like any type of paint job make sure the tyre is clean before you do so eg. tyre shine and that sorta crap, I just wipe over the lettering with some wax and grease remover quick sand with some 320 then apply.
Thanks guys. I'd really prefer spray paint if possible - the stencils never stick on 100% so a brush/pen is likely bleed under the edges (the spray does a bit, too).
But then again that's if you just want to do the raised lettering that's already on the tyres.
Yeah nah, the lettering on the tyres is tiny. I want to go big :)
Mad Mike recommends 'fast dry enamel or primer' in the Tire Bomb post on Speedhunters, might give those a go.
I'm considering getting a custom made laser cut stencil made out of plywood or perspex, would allow me to respray easily when needed...
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
