Wondering where people have sourced their engine hoses from. JustJap can't supply them at the moment, eBay has a few. Autobahn88 have theirs which i am leaning towards. Does any one know where to source genuine Nissan hoses from and are the silicone ones I have mentioned as good.
Thanks guys
https://www.sau.com.au/forums/topic/418478-r33-gtr-engine-hoses/
Not topic specific but I have recently built my motor and opted to go with the ASI hoses off ebay (similar to autobahn88)
they set me back next to nothing and the kit was both good quality and came with every hose that it should have. Fitment was perfect, I just needed to buy worm drive clamps as the silicon hoses are a little fatter.
The silicon will outlive the stock rubber hoses without the fact they are probably half perished from sitting on the shelf for nearly 2 decades.
http://www.ebay.com.au/itm/skyline-R33-R34-GTR-RB26DET-silicone-heater-hose-kit-/280887337908?pt=AU_Car_Parts_Accessories&hash=item416630a3b4&_uhb=1#ht_1240wt_1088
Unless those ebay hoses have become better in the last 3-4 years, I'd be thinking twice... They tend to get spits and fail over time (2-3 years). I had a brand new Auto88 one spring a leak after only 2 months...
Nissan OEM - Lasted 20 years, will last another 20.
Where did you source these from? Tried nissan in victoria. I basically got told off for having an import and they said there is no way they can help me. I actually said that the r32 was aussie delivered and he told me no they werent..ha ha. I hung up
I would rather get OEM can you tell me where?
Have had Auto88 silicon radiator hoses on mine for 4 years now, no issues. Seen several track outings in that time as well. Read about these problems with them leaking a couple of months after I got them and was going to change back to rubber, but haven't had a need yet.
I have done a bit of research on these hoses on other forums. People are pretty happy with these. any other experiences?
Yep ebay noname radiator hose lasted about 2 years for me. IIRC Beer Baron used to recommend the Samco brand if you're going for silicon, but i find silicon hoses are more leak prone than rubber. Rubber just seems to grip better and therefore provide a better seal. OEM only for me for coolant hoses now.
I have read that people have been using zip ties to stop the hoses from creeping. Is it that much of an issue though. I have had similar issues with OEM hoses on other cars that I have owned. Is it really more of an issue with silicon hoses.
I'm yet to have any personal experience with leaking silicon. I've got silicon radiator hoses, so do 3 of my mates, none with any leaking problems to date. That said, where there's smoke... I still keep a close eye on mine to make sure I don't get any leaks.
... recommend the Samco brand if you're going for silicon, but i find silicon hoses are more leak prone than rubber. ...
Provided the silicon hoses are reinforced, doesnt need to be steel but at least with some fibre core than they will out do and perform rubber hoses. Where they are weak and prone to problems is rough hands can damage them very easily and small cuts and nics seem to easily propogate into splits. So dont use screw drivers to lever clamps on and off. Make sure they dont rub against any sharp edges during install and the hose clamps have rounded sealing edges.
When they split early in their life its usually because they were damage by screwdrivers when being installed by Barney Rubble or someone like me :( Rubber is far more ductile it seems and takes abrasion a lot better
Wow were you tapping my phone today. This is exactly what my engine builder said today.
He said that as long as the hoses are 3 ply reinforced or more there is no issue with splitting and they outlast and are more reliable than OEM on high performance engines, BUT care needs to be taken on installing them more than OEM. He said he has seen some failures with people forcing them at an angle and cutting through the inside of the hose.
Messaged the Autobahn88 hoses supplier and he said they are 4 ply, so my engine builder was happy going with them.
So am I with a full set including radiator hoses at $260.
Edited by XGTRX
Oh god... 600-700 bucks for new hoses, I've got my engine out and I need to do the same thing
I know if I get genuine I can install and forget..
With silicon ill always have that question in the back of my mind..
What to do.. What to do
Yeah I know the last thing you want to do is rip the engine out again for those 2 or 3 that you cant get to. Only saving grace for me is that my engine builder said he has never had a failure. so I suppose if I trust him with my whole engine rebuild, I should trust him with his opinion on hoses. Ordering Autobahn88 today. Very nervous about hitting that 'Buy Now' button. Might take some valium before I jump onto ebay.
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
    • It's needed for rolling idle up, and I think it is a decider on VCT also.
    • I mean, not really. Link ECU's can absolutely still have errors from the ECU thinking it's getting a sensor it's not expecting. I would imagine the speed at the ECU level in Nistune does absolutely nothing anyway? I assume the ECU does not do any fancy TC stuff with regards to front+rear wheel speed or anything of that like anyway. Someone who uses Nistune may be more fluent in it.
