So hard to explain! Its the part where the 2 cables join that has the white plastic spring that forms the release for the fuel lid.
Basically just trying to work out how it is mounted as mine is floating around in the boot at the moment. It looks like it clips in somehow but mine stay there so I suspect 'something' is missing.
Let me know if that's makes sense, if not ill take pics.
On mine, the fuel release is screwed in, put I've seen push in types with a spring clip on the end rather than a thread.
** MEANT TO SAY PLASTIC NUT, NOT SCREW :rolleyes:
The fuel lid release appears to be the only part that keeps the bracket mounted firmly.
If you need more pics let me know.
Edited by Nic_A31
Awesome! That's perfect. Mine is missing the plastic nut and looks like the thread has snapped off.
Is the U12 part mentioned in the parts list a direct replacement for the plastic bit? Might have to see what Nissan are asking for them.
  • 1 year later...
Bump. Can anyone confirm this or does anyone have a plastic release for sale? Need one by next week.
Thanks guys,
Ended up finding one on a Ford Corsair (same shape as a U12 Pintara) in Melton. I was super excited, removed it and took it home only to realise the Pintara/Corsair have a passenger side filler and Cefiro has a drivers side.
This meant the little angled piece was facing the wrong way. The plastic piece can be rotated but it requires grinding out the little stud that holds one of the arms together. I did this, rotated the arm, but it back together and then put a small bolt and nyloc nut through the hole to secure it together.
$20 later and I have a working fuel lid and boot again (took me a while to work out the boot as the safety latch keeps dropping down on its own...)
    • This sounds like someone who would have owned an R33 in their past... It's okay, I'm 100% picking up what you're putting down Mark.
    • Just back on what was raised about jacking off the the tow/tie down point on the front of cars. I've used it plenty. I've also watched it on a car where you could see it move the front end of the car. It was like the front end/whole car being tweaked and twisted a bit. I will say, I struggle to find good jacking points on MOST cars. The ones that have good points, I then normally struggle to find a jack tall enough to make the car change height!   One of my go to points for either the jack, or the axel stands though, is either a suspension pickup point, OR a subframe to chassis major bolting point. I actually think its the subframe on my R33 that has a bit of a bend in it, from being jacked in the middle too. However, it could have been one of my many other cars I've had over the years! Or it could also be the from me jacking it up, and the fact the top of the front radiator support isn't there, so it can allow the front of the car to move and bend etc.
    • My apologies. I forgot we were talking about weird beard M series stuff. Had been talking elsewhere with someone about an R33 with similar subject and got confused.
    • Nope, I don't like the look of ND RF, or any ND really, I don't like their faces or arses, why, because of their "modern" lines, the NC, whilst "modernish" has a more rounded shape that I like Well, that's how my overly judgemental eyes see it anyway
    • Should be more than fine, especially the overall fuel pressure would never exceed 3.5bar (assuming that thing never gets more than 0.5bar of boost in stock form). According to the chart, it's 11amps.
