  • Replies 65
Why does everyone have to be nasty? *sigh*
Go shopping at nengun.com, find the parts you want then goto Gavin Wood and get them put on. Front mount, full exhaust, PowerFC, AVCR (or PFC boost module), adjustable exhaust cam gear and yay, oodles of horsies.
yer dude, change ur sig...
as u can see most of us don't take you seriously, probably because of the way you present
yourself...
u have no license, the streets are not smoking and never were, and u seem like you have absolutely no respect for the things you have.
I, (we) have no idea who you are... but it seems that you are in WAY over your head.
and you are not cool for driving without a license...
other than that..
Have a nice day, and happy day crash... I mean driving :)
thanks man i will go to that site now!!
crash, please man, when i do drive which isnt veyr often, i dont drive like and idiot, my signature is just a signature, doesnt mean its true, im a responsible person man!! im not every other crappadore driver out htere, hoon everywhere!!! everytime i go out of my house all i here is a crappadore hooning around!!!! yeh what, and VL's suck, if i were to buy a crappy car i would buy that, i would buy a non turbo silvia or something
dude just some helpfull advice...your hear obviously cause you love skylines as much as everyone but plz take the advice that your getting..these guys have had there cars a long time and some who have unfortuantly been in an accident with them aswell...dont get a car you cant handle spend the money on insurance and get more experenice behind the wheel
yeh man, i am taking the advice aye, cause some of it is actually worth reading but some of it they are saying is just sh*t, so why bother, so yeh aw well,
and this isnt really for u!! but i aint AUSSIE, who ever said i was!!
    • Look for broken wire or bad connector at the motor. Might not be it, but is worth starting there, as it is easy.
    • Hi everyone, I’m having an issue with my R32 GT-R. Sometimes, when the car goes over a bump or experiences some vibration, the 4WD warning light comes on the dashboard. When I check the code from the control unit in the trunk, it shows Code 19 – ETS Motor. However, everything seems to be working fine — if I turn off the engine and restart the car, the light goes away and everything functions normally. Has anyone experienced this before? Where should I start troubleshooting this issue? Thanks in advance!
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
    • 310mm rotors will be avilable from Australia, Japan, and probably a few other places. Nothing for the front can be put on the back.
    • The filter only filters down to a specific size. Add to that, the filter is AFTER the pump. So it means everything starts breaking your pump even if its being filtered out.
