Selling my 1995 R33 GTST, 25/30, 500HP, 380KWATW (safe 98 tune)
Fully engineered and registered till SEPT 2013 for NSW
Motor built by UNIGROUP ENGINEERING using best parts available
Gearbox built and modified by AWARD
Nismo twin plate coppermix clutch
Nismo dash
R33 GTR rear end
R33 GTR rims, Hankook RS3 tyres
R34 GTR front seats
Bonds half cage
White Line sway bars
Adjustable camber arms
Bilstien shocks
Lots of stuff done, you need to have a look.
From some Skyline gigs vvvvv
Best R33 Modified winner at the Shannons Skyline Nationals 2012
Wakefield Class B winner at the Shannons Skyline Nationals 2012
Import Monster SAU NATS Modified 2WD Class, quickest 800mtr
Import Monster SAU NATS Modified 2WD Class, Highest speed 800mtr (245kph)
Selling as the kids are costing me a fortune in dental and schooling and this toy needs to go.
$16,000 ( Ive put maybe 50K into this thing)
Whole car only, Im not parting it out so dont ask, and no holdsies.
If you are looking for a car that can lap Wakefield, run a low 11 sec quater and drive to Queensland for for a cruise then this may be what you are after.
https://www.sau.com.au/forums/topic/418712-r33-gtst-2530-500hp/
Engine specs
Head RB25
Custom exh cam
Drain backs/vents
Drilled out oil returns
RB26 cam covers with MINES baffles
External oil feed (1mm restrictor)
ROSS CAS
Block RB30
JE pistons
Eagle rods
ARP studs
ACL bearings
Hi volume race sump
TOMEI oil pump
EARLS oil pressure regulator
ROSS balancer
Bolt ons
Custom steam pipe exhaust mani
TO4Z
TIAL gate
Greddy copy inlet
600 x 400 x 100 x 3" IC
3" IC pipe
QF45 throttle body
4" intake
Blitz BOV plumbed in
Alloy FENIX radiator
LINK ECU
Limited to 7500
Ishift set at 7200
LINK 7 bar map sensor
GREDDY EBC
Motor and accessories was all balanced.
Thanks
Wow. Can't believe you are selling but you gotta do what ya gotta do!
16k for an awesome all rounder is worth every cent as Dave said.
This car is a cracker, it is a great weekender with track potential.
Best of luck Mark and if I had an extra car hold and the coin I would have transferred the money already.
The Bonds cage is a bolt in, rear seats and belts will go with the car if the new ownwer wants to remove the cage and fit the rear seats back in.
Do not make me go into the whole wife spiel. You sell this and you will not be able to afford to replace it for another decade at minimum. Instead garage it, pay for the dental and the schooling and pick up where you left off with smiles forever more.
If I had 16k I would buy this off you and give it back for free, you just need to keep it that bad.
Car was viewed last night and is on hold for today only.
Spares that will go with the car when sold if you want them
A pair of R32 GTR rims with Mickey Thompson 255/50 16 ET street drag radials;
A set of std discs;
Pair of rear king springs;
Some boot trims;
A spare RPM racing harness;
A fire ext;
A pair of OMP gloves;
A RPM balaclava;
Some new silicon hoses;
A KBC full face helmet;
First aid kit;
And some oils and fluids.
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
