Eflex = 70% ethanol, and has always been.
I have been running United for a few years, I ran out recently on a long trip and had to fill on Caltex Eflex, the tune was only a little rich and I didn't notice any difference driving the car. If you plan to fill on both just tune on the United e85 and enjoy.
https://www.sau.com.au/forums/topic/419241-e85-act/#findComment-6736228
  • 1 year later...
Saw a banner for E85 at the Sutton United last time I drove to Sydney.
I called them today to check they had it before I drove out there to fill up. The guy I spoke to said not yet but they will be starting the work soon (tanks or bowsers I guess?) But that he thought Fyshwick might be ready now.
https://www.sau.com.au/forums/topic/419241-e85-act/#findComment-7191253
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
