Hello you beautiful people you, I just would like to know what solutions you previous RB25 swapped R32 GTS-T Gurus had for;
1. The different sized heater hoses
2. The throttle cable mounting bracket
3. If anyone else has had an issue with the aircon belt being horrendously loose?
and 4. I have a series II RB25, can i swap in RB20 coil packs to mesh better with my RB20 Harness, or am I just completely shafted?
A pre-emptive thanks for any and all input.
Also: I'm not spamming separate threads, I apologize, I just honestly don't know where to drop this topic.
https://www.sau.com.au/forums/topic/419436-rb25det-r32-need-some-final-help/
Alright, final snyopsis on my coil pack situation is this;
Running an RB25 Series 2, with Series 2 ECU and Coil Packs, with RB20 Harness. This won't work, obviously, so my question is can I swap out the Series 2 ECU for a Series 1, and to supplement that, swap out my coil packs with Series 1 Rb25 or RB20 coil packs? Would that be my only way to make this engine run with the given parts installed?
pretty sure most people get all the parts to match the engine i.e have all S2 engine, coils, harness, ecu = no problems.
dont know for sure whether s1 ecu works with s2. why didn't u look into this beforehand and just gone with the tried and true methods?
Use Rb20 harness igniter and coilpacks, then wire up an extra wire for the VCT. series 2 ecu should work, but if it doesn't just grab a series 1
OR The much much better solution. Use Rb20det ecu with nistune and get it tuned.
Spurdo; I simply trusted the wrong sources, I have an issue with getting parts to where I'm at, so I had the engine and ECU ordered as one through someone off-base to be shipped to their house, and trucked into the auto shop for me, but they didn't think to look for a Series 1, instead choosing the better option engine with less miles and an attached clutch. It just happened to be a Series 2, unfortunately, which puts me in my little predicament now.
4DOOR; Thanks a million, finally the answer I was looking for. Luckily the local junker has an HCR32 with an RB20DET i can snag the coil packs off, as well as a Series 1 ECU in there somewhere. You're a lifesaver mate.
you can also use rb25 s1 coilpacks they are the same. its just easiest to use the rb20 loom cause everything for the body is already done. you also need to get the injector plugs for the 25 and cut the old ones off the 20 loom and solder the 25 ones on cause they are different.
Yeah, i have the harness in and built, that's exactly what I did, everything is solid save for the injectors, I realized what was wrong almost immediately, but hey, still got the engine to fire and idle on the first try, but any prolonged use with the S2 coil packs hooked to the ignitor would cause some coil pack blowouts. With the RB20 loom and ignitor, I am pretty much forced into using the Rb20 Coil packs, aren't I? If I understand right, the earth ground, 7 prong plug is on opposite sides of the ignitor for RB25 and RB20, correct?
    • Pads for R32 GTS-t, R32 GT-R non V-Spec (Sumitomo), R33 GTS-t and R34 GT-t are all interchangeable. R34 GT uses a 2x piston caliper, hence it didn't fit.
    • Checked with amayama and nope, the full S2 manual set is not available anymore. Unsurprising, but still disappointing as the ? on availability gave a glimmer of hope.
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
