Wrecking Built R33 Rb25/rb20/sr20 Performance Parts Available - Garrett 3071/blitz/sard/bosch/gfb/wolf/hybrid
WOLF V500 Direct plug in ECU for RB25DET R33 - $500, take it away! The current model of this ECU retails at $1,995.80 incl GST:
http://wolfmotorspor...3-gtst-plug-in/
This ECU is a direct plug in ecu which plugs into factory harness - no chopping harnesses or piggy backing harnesses, very clean installation capable of producing great results.
Inludes laptop plug - great condition, like new, also ran great when installed in the car - removed from parted vehicle which was not smashed or damaged at all
Spec attached in pdf. file attached below.
Wolf_V500_Specification_Sheet1.pdf
Still available below! prices very negotiable!
HKS Super Drager CAT back was $500 now $300
Clutch Kit $200
Series 2 front Bar - slight dent on front and pre cut for cooler $150
Series 2 headlight right good condition $300
Series 2 reo $100
post-30339-0-80235100-1360219532_thumb.j
Blitz 850cc Injectors in stock rail - $450
16 inch R32 GTST wheels and tyres 90% tread $450
Series 2 Bonnet - straight as - perfect - $400
17x7 inch wheels and tyres 80% tread $300
post-30339-0-10499500-1360219648_thumb.j
Front callipers $270 $100
Rear 5 stud hubs $120
Manual LSD 4:11 tight $200
Driveshafts $180
Stock suspension $150 $80
Front rotors $50
Front 5 stud hubs $50
Rear lower control arms $50
post-30339-0-76123500-1360219563_thumb.j
post-30339-0-67879800-1360219593_thumb.j
post-30339-0-51298400-1360219629_thumb.j
Side skirts custom $120 $80
Front windscreen $100
Rear windscreen $80
Front guard left $60
Front guard right $60
Door Rubbers full set $70
Rear wing series 2 style but a little taller aftermarket? $50
Quarter windows $50
Front door windows $50
Mirrors $40
Tail light left $40
Tail light right $40
Rear garnish $40
GTST Badges $40
Left Door $30
Right Door $30
Wipers and motors $30
Misc Manual Conversion bits $200
Air con compressor $120
OEM Coilpacks $100
S1 engine loom $100
Cross member $80
Power steer rack $80
Radiator $80
Engine mounts $70
Alternator $70
Power Steer bottle and hoses $40
Radiator overflow bottle $20
Fuse box lid $20
RB25 Exhaust manifold $50
post-30339-0-70982000-1360219662_thumb.j
Dash cluster 150xxxkms - worked perfect $120
Drivers side window motor $100
Jap steering boss kit and AUTOTECHNICA wheel $100
Instrument cluster with vents $80
Seatbelts $80
Ignition barrell and locks $80
Drivers side window switch $60
S1 Door trims and quarter trims - slight marks $50
Passeneger side window motor $50
Series 1 Front seats $50
Steering column surround $50
Gear selector surround and boot $40
Center console $40
Climate control unit $30
Rear seat $30
Rear parcel shelf/child restraints/factory speaker grill $30
Indicator switch $20
Wiper switch $20
Still available below! prices negotiable!
HKS Super Drager including high flow CAT back now $250
Series 2 reo $100
16 inch R32 GTST wheels and tyres 90% tread $350
Manual LSD 4:11 tight $180
Driveshafts $180
Stock suspension $80
Side skirts custom $80
Rear windscreen $80
Quarter windows $50
Mirrors $40 each
Tail light left $40
Rear garnish $40
GTST Badges $40
Left Door $30
Right Door $30
Wipers and motors $30 (front motor sold)
OEM Coilpacks $100
S1 engine loom $100
Cross member $80
Radiator $80
Engine mounts $70
Alternator $70
Fuse box lid $20
Seatbelts $80
Ignition barrell and all locks matching key $80
Passenger side window motor $50
Center console $40
Wiper switch $20
 Share
    • Wow mate that's huge, congrats. Glad you found better people to deal with and all seems like it's going in the right direction.
    • The best setting for street is what gives the best tyres wear for your driving style Different tyres like different camber You want the whole surface of the tread to wear flat, if the inside of the tyre is wearing more than the outside reduce camber settings For toe, have the minimum amount to give the handling you want Caster, from my experience if you can adjust it, is as much as you can get without clearance issues And while -2.5° of camber on the front might work well with good tyres for "spirited" cornering, it may be too much for a street car Lots of front camber will effect braking Just like to much rear camber will effect rear traction (rwd), and braking  When I set my Bogan Cruise Ship (VX SS) up for drags I tested how much tyre width I actually had in the rear by doing a hard launch (skid), it originally had -1.5° in the rear, and you could see that the tyre wasn't putting down alot of the tread, I maxed out the settings to get as little camber as I could with the OEM adjustment and some camber bushings and got it down to just under -0.5° with 0 toe, that gave me a fair bit more "rubber on the road" and helped it hook up for my 60' and my 0-100kph And with -1.5° in the front the big old boat handles fine on the street and my tyre wear is nice and even on both front and rear tyres (currently Hankook RS4's) As for semi slicks at the track, again, it depends on alot more IRT the suspension, the track and lots of other things, so, I'll leave that up to people who have more experience, especially with a AWD In saying this, street settings are pretty easy, just look at the tyre wear Meh, Necro thread, it's late at night, and I has been drinking beer
    • Thought I'd give an update. There needs to be scarce details in some areas due to ongoing discussions. Here's the journey of trying to make the booked registration appointment (again). Sent a complaint to Car Inspect outlining the concerns and made some demands. Went to a service center in Geelong, got assaulted with bullshit items on the RWC, as you know. Tried to quote $2.5k AND wanted a structural report Only seemed to be one place around Geelong that does them, they demand $495 just to end up telling me it's f**ked, at least $11k to fix and tried to sell me his own Skyline in the process (bro, wtf?) Started stressing about what I'm supposed to do with this possible pile of steel. Awaiting that, I was sent an angel friend who works in Melbourne and knows real mechanics and body shops.  They laughed at the reported quotes (don't get work done in Geelong) Car underwent some front surgery and brought back better They then sent it to the mechanics for RWC Registration appointment is two days away at this point. Mechanics pointed out two issues: driver's seat and shocks - that's it. He offered couple options and I chose coilovers. Frantically I scoured the jungle realm that is Facebook Marketplace (again). Found what looks to be a decent Series 1 seat actually - $100 Guy is friendly, offers to bring the seat with a colleague who's heading to Geelong (thanks man, that was cool) Seat arrived, looks good. Throw it in my car and drive to Melbourne and drop it to mechanic T-1 day, mechanic reckons job will be done for the fronts only, gets it done by 4PM Mechanic heads to get the coil-overs that night as a favour to help me make the appointment Get driven to Melbourne, drove the car back - RWC Unlocked! ✅ VicRoads tomorrow, the goal is close now. 🙂
    • Gtr are still available through the heritage program but don’t have the wiring
