Sorry for another actuator thread and I have searched but my problem seems a little different.
I went for a drive yesterday and the drivers doors wouldn't unlock with either my fob or the key in the lock. There is resistance from lock and when I use the fob there are no flashes unless I press the lock button. I ended up going through the boot and opening it using the switch to unlock the but if I use fob or key nothing happens for locking or unlocking regarding the locking mechanism it self. I don't fancy leaving the car unlocked or climbing through the boot each time so hoping for some help/advice.
I'm wondering if I replace the actuator will this solve my problem or is it something else freezing up?
Cheers in advance
Niall
P.S Passengers door doesn't move either but never has(actuator gone)
https://www.sau.com.au/forums/topic/419536-actuator-gone-or-something-else/
Sounds strange, but i have been researching for weeks trying to find a half decent video/images guide on how to replace the door lock actuator as i have a new one sitting at home but i can't manage to get my arms into the tiny space to work with it.. and i don't fancy the idea of removing the window.
i seem to have a thing for saying "id be checking the fuses" latey.... but yeah thats what i'd do. sounds like the locking system could have no power, turning the key would feel heavy because its not being electrically assisted.... pressing the lock botton on the window switch panel should also have no effect (but thats assuming its not an independant circuit)
it could well be the actuator tho
Hmmm well the key and fob both started working again this afternoon and then all of a sudden stopped. The lights now seem to work when I use the fob and sounds like the lock is trying to move but nothing happens along with when I use the key. I'll check all the fuses tomorrow and also try and remove the door panel to see. I can't seem to find the diy on how to replace the oem actuator.
i took the entire trim off when i replace my window motor, the door lock is located in a stupidly tight place. Right up in the corner, it's not an easy job i haven't tried it yet but it looks tricky as hell.. that's why people opt to do the $5 fix which you can find the DIY on g35driver.com
Yeah I've looked at the $5 fix not sure whether to go for it or not, I'm going to have to get my hands on the packs if I do but I'd rather replace the oem part to be honest as long as I could find the DIY with pictures.
I'll probably try replace it next weekend with a mate, if you find a DIY please let me know mate. I have looked over the internet a fair bit though so unless it's been put up recently i don't think you'll have much luck :/
gut the door... so glass out, wind reg out, guide rails out,
already said this 3-4 times now.. if you are not confident in doing it pay someone to do so :)
There isn't anyone worth paying in Mackay. Think that that's the problem.
Ended up doing the actuator fix tonight. Was a pain in the ass but seems to be working quite well now. Been wanting to do it for over 2 years now since i bought the V. Couldnt bring myself to drill holes and cut off pieces of the lock.
Bought a spare interor door handle just in case I screwed up.
Edited by jjjones
i did it over the span of 3 days.
1st day i taped the central locking wires behind the speaker (20mins).
2nd day i created the bracket and mounted the actuator on it (30mins).
3rd day i drilled holes in the lock and door card and mounted everything (2 hours).
Its actually a very easy fix to install. The only thing that worried me was making sure i was drilling holes in the right spot to have it all aligned properly.
I would suggest buying a spare interior door handle. The fix requires you to snap off a tab in the handle which means if you decide not to go ahead with the fix and want everything back to the way it was, the lock cable has a high possibility to fall out.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
