Does anyone know of any triple gauge holders you can get for the R34 N/A to sit in the center dash where the little imprinted storage space is?
Ive looked at the GTT ones of ebay but it looks like you have to drill into the dash to hold em in.
The dash isnt like falcons and commodores where you can unclip the center bit and then the gauge holder will clip in.
If there are any where can i get em from, or will i need to get one custom made?
You can't get OEM tripple gauges for NA, though you can buy the OEM cover and retro fit aftermarket guages on. I have both the dash and tripple gauge cluster for sale if you're interested. PM me.
Turbo 34s have that "imprint" square area cut out and thats where the OEM gauges sit.
Can do it but you will still need holes for wires etc cut in the dash top
Did this to a couple of n/a cars, you need to be neat and fairly precise with an angle grinder and diamond blade. Under all that crap are the rear clips where the factory triple gauge hooks in, and the screw holes for the front part sit under the airvents. You can't tell it's been done when fitted correctly. (ignore the random look of the interior, my car had just been recovered from a chop-shop)
So did you do this completely DIY? Because the only thing im concerned about is ruining the dash, there surely has to be a triple cluster out there that just sits on top or something?
Yeah it was easy, you just need a steady hand and measure a million times so you don't leave yourself with any gaps. Generally cut the hole 1.5cm undersized and use your finger to slowly and evenly remove the foam from under the plastic, the plastic just folds neatly and the triple gauge cluster hides the evidence.
Did you find that the aircon vent gets in the way though? Because when i had my head unit out it looks as if the vent is almost touching the top of the dash, just looks like its in the way
Take the vents out, behind the vent you'll see the screw holes that line up with the ones on the triple gauge, that's where it joins up. The n/a dash is a GTt dash without the hole cut, everything is basically exactly where it would be on the turbo car, just hidden under a plastic cover that needs to be cut out.
here's a thread I contributed to a while back, has all the info you need :)
http://www.skylinesaustralia.com/forums/topic/282281-r34-gtt-triple-gauge-into-na/
Edited by 666DAN
http://www.skylinesa...-gauge-into-na/
Ahhhh was about to say i could get a picture but Dan nailed it!
I saw mention of Blue Tack holding in the gauges, surely that cant last? :P
The main thing is to give yourself a nice bit of room so you don't remove too much dash plastic and have gaps at the edges. Use a nice sharp stanley knife and a ruler to mark out the area, then just peel the foam and plastic off the dash (the hard plastic just under) it's messy as and you'll have yellow foam all over the place, have a vacuum on hand. Once you've exposed the hard plastic, the angle grinder and cutting blade sorts it in seconds (WATCH THAT WINDSCREEN)
LOL maybe it's the structural type? That's just cringeworthy, even a glue gun would have sounded less shoddy (just)
Industrial strength? :P
Going to try tackle my gauges sunday arvo after the SAU cruise.... Will keep an eye on this thread to see how OP goes!
I wouldn't use a grinder cut off wheel
A multi function tool or air saw
The grinder makes a mess and is dangerous as hell , grab the dash and flig thru the window or cut you or the car to bits , and throws crap everywhere !
the other two can cut the dash like butter a s cleaner cuts , if you drop it or catches they stop dead
the fumes from burning / melting abs plastic can be dangerous or even fatal too so do it with fresh air / mask
take a look at a gtt dash hole first its pretty simple cut the line is more or less molded in the dash to guide you ?
Don't scare monger, a diamond blade slid through it (as do the wafer thin cut-oof wheels), and becasue of the materials involved it couldn't catch if your life depended on it and there were no fumes at all. As for mess, the foam removal is a 1000 times worse as it's aged and friable.
Basically if you're out of your depth safely controlling an angle grinder (lack forearm strength and delicate control) don't attempt using one and use an alternate method.
If you're really bad with electric tools, spread peanut butter over the area and put 12 rats in the car.
:laugh: nice one
:laugh: nice one
Scare monger!! Have you seen what a grinder will do , not to mention in the hands of someone who doesnt use one often. Or ever!!
Better safe then sorry i enjoy having limbs and a car window
Forums assume the person had skills and we all know that is a coin flip
Best tools for the job is airsaw or multifunction tool IF you have access to one
End of story
Why bother suggesting shit to these forums users if thats the BS you put up , would have expected more dan !! ffs
Next thing ya know the person got seriously hurt
    • That is surely the biggest gathering of Stageas in North America, ever!
    • Remember kids - if you can't afford to buy 2 GTRs......
    • I know people cry at the price of the Getrag 12-14k for a conversion now, but it really is a nice mid point. Not going to get change from 10k on a gearset installed.  $30k++ for sequential.   I know you run the risk of a damaged used one and parts are hard to get but as a street car gearbox its really hard to beat. If you enjoy a more traditional manual, its the choice no question.
    • Time to decide what’s more import, your power level or your budget because you’re going to struggle to keep both
    • Our Southern Highlands Cruise is proudly registered with “R U OK?” Day.  Sometimes the best way to check in on your mates is by getting out for a drive together. Sharing a common passion like cars creates the perfect space to chat, connect, and support each other.  A simple “R U OK?” can make all the difference. Let's enjoy the drive, the company, and look out for one another. PLEASE WEAR YELLOW FOR “R U OK?” DAY Sunday 14th September 2025 9:30AM Meeting Crossroads Homemaker Centre 10:00AM Cruise Departure Via Old Hume Hwy 11:45AM Arrival at Mittagong RSL Club Meet Location: Crossroads Homemaker Centre Final Destination: Mittagong RSL Club *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
