What was previously thought to be a Coil Pack issue now looks like an Air Flow Meter problem.
My Power FC is showing an AFM1 reading of as low as 0.4 while AFM2 is steady at around 0.75. This causes the car to shake, idle rough and lose power while driving.
Sometimes this happens constantly. Other times the Power FC will show both AFM's hovering at 0.75 and the car purrs like a kitten and drives like normal.
Does anyone know whether AFM1 needs to be replaced or is this an issue with the connector/earthing?
I haven't tried cleaning the connector with a spray (I was planning on buying some spray tomorrow).
https://www.sau.com.au/forums/topic/420225-r34-gtr-air-flow-meter-issuehelp/
"This causes the car to shake, idle rough and lose power while driving."
is the lose power while driving at any speeds, or while still in first? i know its a diff car but my BMW had a similar issue and it was resolved by replacing the MAF
Thanks guys!
The loss of power is constant. as soon as AFM1 voltage drops down, the car starts shuttering like it's choking. Every gear and no particular RPM. Had to roll home slowly.
I unplugged AFM1 and it started shaking etc. Plugged it back in and it started idling perfect. This is why I'm thinking maybe its the wiring and not the actual AFM.
As mentioned by basti sounds like it could be the solder inside one of the units meant to be a common thing that can happen ! Are they standard AFM ? Swap them out with someone see if that fixes it if so might be time for an upgrade! Nismos maybe ?
Or just leave them plugged in and run a map ecu. Standard sir
lol he's on his P's in a car that is FAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAR from stock.... AFM's are the least of his worries :P
Chris just swap AFM1 with AFM2
If AFM2 starts playing up you know it's the AFM. If it's still AFM1 then it's electrical.
Realistically though they usually don't drop to 0.4 - they will drop to 0.0-0.03 which will make them flash error/failure intermittently on the PFC... That's just what I found over the years anyway.
Ditch the AFMs, hide the plugs, and get a PFC D'jetro :D
And go through a roadside EPA station and fail instantly because they can't find the plug or do find the plugs, pull them off, car still idles ok - instant fail and easiest way for them to check for full aftermarket setups. Once they get you that way you just get written up for a full inspection on the spot and then they get the camera out which is the worst thing that can happen :thumbsup:
I'm off my P's now :)
Good idea Ash. I'll swap them around and see what happens.
AFM2 is a pain in the ass to get to lol.
If I need to replace the AFM, I doubt I'll be able to get one in time for Tony's wedding!
Because GTR.
I remember Ash popping a cooler pipe at DECA in someone elses GTR... Full toolkit, 2 guys who know their way around.... 30+ Minutes later...
UPDATE: I swapped the AFM's around and it's still AFM1 which has the voltage issue. I guess this rules out an issue with the AFM.
Anyone experienced this before? Could it be the wires leading into the connector?
Because GTR.
That was a pain in the ass, inner guards & supports FT, we cut corner and didn't put anything back in though L lol
AFM's are a bit more fiddly, not too hard though - certainly need less tools :D
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
