Import Monster Sauvic Deca Motorkhana - 16Th March 2013 - Entries Open
I've filled out the form, I'll try and get it faxed this afternoon or tomorrow morning. Hope this is okay!
You can also email it to the address on the top of the form if that's easier :)
  • Replies 139
Hey, I have bolted my fire extinguisher to my tranny wall passenger side. Is this going to be ok?
I used grade 8 5/16 bolts and lock nuts (all I had lying around)
The nuts are under the car near the gearbox?
I get my car back Friday night so I don't really have time to change it.
How's the sil80 Russ? All good to go?
Are you trying to be a smartass? lol
Perfect. Any bolting of bolts into a metal surface is fine.
Guys, have a couple boys coming with since we are towing the car. Is that okay?
More people the better ;)
lol :whistling:
Ok our volunteer officials list is looking good at the moment.
Thank you to all who said they can help out.
But im still after a few more just to help the day run better.
If you have a mate or mates coming up and can help come see me sat morning.
Cheers WayneO
Hey guys, do we have to wear long sleeve shirts?
In the first post of this topic there is the Supplementary Regulations : http://sau.ferni.net/DECA/1316_Mar13/EntryFormMarch2013.pdf
The section regarding Apparel says you need to be covered from ankle to wrist. It'll be warm, so I recommend a lightweight cotton long sleeve shirt and jeans, nothing worse than a hot day and being stuck in a hoodie!!
You will not be allowed to compete unless you meet the requirements of the supp regs.
My clutch went last weekend, been trying to fix it all week but looks like i'm out of time :(
Please take me off the list. I will still come up to watch and show my support :)
Sorry about the late notice
know how that feels, my clutch is in, engine work done but still searching for a front hub/bearing.
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
