lets call it $14500ono open to offers to sell as is or willing to sepearte if there is enough interest..
- car just needs a turbo and pipe work to be running again! 99% complete! Then some paint and she will be sweet
- Plenty of serious parts
Engine
RB25 series 2 motor (88,000Kms)
Plazmaman Plenum
Plazmaman throttle body
Steam pipe high mount manifold
Splitfire coilpacks
Big Injectors
BMI fuel Rail
Front Mount
52mm Radiator
Oil Cooler and relocation Kit
Tial 44mm External Gate
r33 clutch master
3.5inch kakimoto exhaust
Custom Front/Dump pipe
Greddy Swirl Pot
Fuel Pressure Regulator with Gauge
Big lift Pump (unknown brand)
2x 044 bosch
Interior
Profec B Spec 2 controller
Adaptronic computer
ARK turbo timer
Bride door trims
Bride Gias II Seats
Custom Seat Rails
Prosport Boost Gauge
Prosport EGT Gauge
Prosport Oil Temp Gauge
Prosport Oil Press Gauge
Prosport Water Temp Gauge
Pioneer MVH-8250BT head unit
6x9 in rear
Custom parcel shelf
6inch in the doors
Cusco Half cage
Suspension/Driveline
R33 LCA's
ISC N1 coilovers
Adjustable rear camber arms
Bolt in half cage
metal pinapples
mini spool
Exedy 100kg heavy duty clutch
Strut Braces front and rear
Hicas Removed completely (all lines)
R33 power steering pump
Hicas Lock bar in rear
Wheels/Tyres/Brakes
Meister S1R (brand new)
Front
18x9.5 -30
Slotted Rotors
Rear
18x11.5 -47
315/30 semi slicks
Body
CUSTOM CUSTOM CUSTOM
Spared no expenses on guards
Custom moulded to car
Custom inner arches in rear
Veilside Front Guards
Veilside Rear Guards
veilside Side Skirts
Carbon exhaust shield (ultra rare)
Im sure i have missed plenty of parts details
car is located on Central Coast NSW
https://www.sau.com.au/forums/topic/420462-eoi-widebody-r32-for-sale-or-strip/
Does it come with standard replacement parts ? What about turbo side ?
What does that price exactly include?
bare motor, if you want the plazmaman plenum etc we can work out a price! im open to offers
Engine
$1000
Plazmaman Plenum
$600
$60
$400
BMI fuel Rail
$125
52mm Radiator
$125
$250
Tial MVR 44mm External Gate
$350
Greddy Swirl Pot
$70
$50
2x 044 bosch
$180ea
Interior
$250
Adaptronic computer with plugin harness
$850
ARK turbo timer
$130
Bride door trims
$250
Bride Gias II Seats
Custom Seat Rails
$1000
Prosport EGT Gauge
$550 set
Cusco Half cage
$600
ISC N1 coilovers
$600
mini spool
$450 (in housing)
$100
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
