I’m stripping the donor car that I just purchased. It has 150K on the clock. It doesn’t run, so parts are as is and I think the prices should reflect this.
Note: I’m keeping the engine and a few ancillaries. I’ve listed what I’ve removed from the car so far. The rest is up for grabs, but it will take some time to remove the remaining parts.
Location and conditions: Prefer pickup for larger items, but shipping can be arranged a buyer’s cost.
I’m in Kinglake and can bring to work with me at Mulgrave if you want to collect during the day.
Contact: Jack on 0401994746, or PM me
Item: Standard exhaust from dump rearwards with canon muffler attached
Condition: Few scratches, but seems in OK condition - meh, it’s an exhaust!
Price: $80
Item: Standard radiator with shroud. Has oil transmission in/out bungs
Condition: Second hand, Fins look OK, it has a few dings as you would expect. Looks OK to me. As is.
Price: $80
Item: AC condenser, compressor, cannister and piping
Condition: Second hand, as is
Price: $80
Item: Standard intercooler with shroud, mounts, all hoses, clamps, piping
Condition: Pretty good nick, I reckon.
Price: $100
Item: Auto diff & cross member with Hicas attached
Condition: Hasn’t been run up, so I can’t vouch for its operation
Price: $100
Item: Front bumper
Condition: Gun metal grey, definitely needs a sand/spray
Price: $90
Item: Rear bumper with side pods
Condition: Maroon (wine red?), will need a spray
Price: $90
Item: Bonnet
Condition: Silver, previous owner sanded it and left it that way – so will need painting
Price: $50
Item: Spoiler
Condition: Maroon (wine red?), looks OK
Price: $50
Item: Left and right electric mirrors
Condition: White – looks unpainted. Can’t test them, but look in newish condition
Price: $100
Item: Standard intake hose with piping attached
Condition: Looks in good condition
Price: $80
Item: Set of genuine Skyline mats, including the transmission tunnel mat
Condition: Used, but scrub up OK
Price: $100
Item: Pair of tail lights
Condition: Maroon (wine red?), average condition
Price: $50
Item: Pair of S1 head lights
Condition: Average condition & a bit hazy, but can be polished up as per the countless threads on how to restore headlights
Price: $90
https://www.sau.com.au/forums/topic/420596-stripping-r33-gtst-s1-auto-in-vic/
Do you have the passenger side inner guard lining? The front piece. Although both sides would be handy. Also do you have the under engine tray?
I assume you mean the front passenger inner guard lining? and the engine tray between the radiator and engine? Then yes I do. The drivers side inner lining is stuffed though.
has the box had any work done mate? also.. how much for afm and ecu?
dunno whether the box has had any work. Haven't pulled it out yet.
AFM and ECU pricing in a PM to you.
  • 1 month later...
    • Pressure when IDLING, is meant to be 51PSi... So that amperage value needs to go up a fair chunk... I'd personally be factoring for more like 12amp at least on those runs, and at that point you need to hope the already there wiring doesn't drop you a volt or two, as that's a lot of fuel pressure flow drop off from 13.5 to 12V! Taking idle pressure of 51psi, means the pump will be drawing a MINIMUM of 9amps all the time based on your reading of the graph (3bar base, then allowing an extra 0.5bar for boost = roughly 51psi)
    • Hi all,  I am in the market for an R200 longnose diff out of a Z31 300ZX, or S12 RSX, DR30 skyline, or similar, in a 3.9 ratio.  Preferably a late model one with the M12 crownwheel bolts.  The only easy to find advert for one of these was my ad back in 2007 when I sold it on this forum.  I sold the diff as I had sold the car it goes to, but as it turns out, after 18 years I got the car back late last year, so now I'm looking for the diff !  If anyone knows where to find a longnose R200 LSD with the M12 crownwheel bolts, drop me a line at [email protected] - Bonus paid if soomeone comes up with the original diff (stranger things have happened !).  Cheers   Ben D
    • Hi everyone, I used to post here a bit from 2004-2013, when I owned various Nissans, in particular my S12 RSX gazelle, which was sold in 2007.  As luck would have it, after an 18 year hiatus, the car found its way back to me last year, and over the past 11 months I have had the pleasure of restoring it with my kids.  One thing that I am after in particular is a 3.9 ratio R200 LSD for it.  I actually sold the one out of the car here back in 2007 , and it would be incredible if I could track down who I sold it to, so I can see how they have progressed over the years (and to be honest, to see whether I can get the diff back !).  Anyways, hi all and let me know "where are the R200 Longnose diffs all at these days ?  Cheers Ben D
    • Arms will be the same as the G35 or 350Z, but as above, there was a change in the lower control arm where it connects to the ball joint.  That said, you can remove the ball joint cone from your old ball joints and fit them to the new ball joints.  To be honest, I didn't think the ball joints themselves were different. The main ball joint is a bit awkward to replace, you really need to remove the steering knuckle to press out the old one.  Some people have used tools to remove it in place, but it just seemed too hard to get to. If you are going to press out/in that ball joint, then you may as well just replace the bushings in the LCA and the compression rod.  You can buy the compression rod bushing from Nissan, but the LCA bushes, you will need to go aftermarket. Much cheaper than buying the whole arm.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
