Up for sale is my pride and joy..
1999 R34 GTR V-Spec in Kr4 Silver
60,000kms
selling to fund an investment property.
car currently has 358awkw tuned at Morpowa on 98 octane.
modifications include:
Trust T517z turbos (10cm)
Tomei 260/260 Camshafts and cam gears
Power enterprise 700cc injectors
Jasma full twin system exhaust
Nismo AFM's
Nissan N1 spec water pump
post-80026-0-70512000-1361775827_thumb.jpg post-80026-0-97261500-1361775879_thumb.jpg post-80026-0-42402600-1361775895_thumb.jpg
post-80026-0-88486000-1361775922_thumb.jpg post-80026-0-79179300-1361775962_thumb.jpg post-80026-0-05820500-1361785976_thumb.jpg
post-80026-0-80493600-1361787422_thumb.jpg post-80026-0-79298100-1361787461_thumb.jpg post-80026-0-19263500-1361787500_thumb.jpg
Trust oil cooler kit
Blitz 600hp front mount intercooler
twin thermo fans with triple core radiator
standard air box with K&N filter
Splitfire coilpacks
ported turbo manifolds
bosch fuel pump
trust oil catch can
TEIN coilovers
Cusco camber arms
Alcon 365 6 pot front brakes
Alcon 335 4 pot rear brakes
project Mu pads & titanium wheel nuts
Volk TE37 18X10+12 matte black wheels
toyo 265/35 T1r tyres
Nismo clear indicators
factory uv cut privacy glass and dark tint on windows
NISMO 320kph dash reading 27,000kms also have original dash reading 32,000kms
kenwood cd player and speakers
blitz dual sbc
apexi hand held power fc
blitz turbo timer
Ogura twin plate clutch
and much more...
over $36,000 in receipts for work done recently
just spent $700 on full service at Manta Automotive
serviced every 5000kms have all history on car with receipts.
car is meticulously cared for and rarely used
non smoker - washed weekly
premium plates 'XX 034K'
have lots of standard parts which go with the car
please call me on 0411 768 931 for more details
Thanks Sam
PRICE $54,999
Edited by APE
https://www.sau.com.au/forums/topic/420597-r34-gtr-vspec/
No idea sorry mate I did not remove it, is it important?
Car has no accident damage or evidence of repair and has matching numbers etc. I have a fast screenshot but its on my work computer will post later this week.
Sam
https://www.sau.com.au/forums/topic/420597-r34-gtr-vspec/#findComment-6772102
I'll give this a free bump purely because it's everything I'd be looking for in a GT-R.
Unfortunately, the timing is not quite right for me at this point, and believe me, I ran the numbers more than once!
Good luck with the sale.
Edited by ActionDan
https://www.sau.com.au/forums/topic/420597-r34-gtr-vspec/#findComment-6802549
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
