Up for sale is my pride and joy..
1999 R34 GTR V-Spec in Kr4 Silver
60,000kms
selling to fund an investment property.
car currently has 358awkw tuned at Morpowa on 98 octane.
modifications include:
Trust T517z turbos (10cm)
Tomei 260/260 Camshafts and cam gears
Power enterprise 700cc injectors
Jasma full twin system exhaust
Nismo AFM's
Nissan N1 spec water pump
post-80026-0-70512000-1361775827_thumb.jpg post-80026-0-97261500-1361775879_thumb.jpg post-80026-0-42402600-1361775895_thumb.jpg
post-80026-0-88486000-1361775922_thumb.jpg post-80026-0-79179300-1361775962_thumb.jpg post-80026-0-05820500-1361785976_thumb.jpg
post-80026-0-80493600-1361787422_thumb.jpg post-80026-0-79298100-1361787461_thumb.jpg post-80026-0-19263500-1361787500_thumb.jpg
Trust oil cooler kit
Blitz 600hp front mount intercooler
twin thermo fans with triple core radiator
standard air box with K&N filter
Splitfire coilpacks
ported turbo manifolds
bosch fuel pump
trust oil catch can
TEIN coilovers
Cusco camber arms
Alcon 365 6 pot front brakes
Alcon 335 4 pot rear brakes
project Mu pads & titanium wheel nuts
Volk TE37 18X10+12 matte black wheels
toyo 265/35 T1r tyres
Nismo clear indicators
factory uv cut privacy glass and dark tint on windows
NISMO 320kph dash reading 27,000kms also have original dash reading 32,000kms
kenwood cd player and speakers
blitz dual sbc
apexi hand held power fc
blitz turbo timer
Ogura twin plate clutch
and much more...
over $36,000 in receipts for work done recently
just spent $700 on full service at Manta Automotive
serviced every 5000kms have all history on car with receipts.
car is meticulously cared for and rarely used
non smoker - washed weekly
premium plates 'XX 034K'
have lots of standard parts which go with the car
please call me on 0411 768 931 for more details
Thanks Sam
PRICE $54,999
Edited by APE
https://www.sau.com.au/forums/topic/420597-r34-gtr-vspec/
No idea sorry mate I did not remove it, is it important?
Car has no accident damage or evidence of repair and has matching numbers etc. I have a fast screenshot but its on my work computer will post later this week.
Sam
https://www.sau.com.au/forums/topic/420597-r34-gtr-vspec/#findComment-6772102
I'll give this a free bump purely because it's everything I'd be looking for in a GT-R.
Unfortunately, the timing is not quite right for me at this point, and believe me, I ran the numbers more than once!
Good luck with the sale.
Edited by ActionDan
https://www.sau.com.au/forums/topic/420597-r34-gtr-vspec/#findComment-6802549
    • Given you're running a 2.8 and my 2.5 is not really like for like, I suspect there could be a bit more timing you could give it. What is the kW yield per degree you're putting through it? Here's my E85 map to give you an idea, where it was I could still get another 3~4kW per degree thrown at it.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
