Hey guys, I'm half way through fitting a front mount and am wondering g what to do with the washer bottle set up in the front right corner. The piping will foul it. Do I mount it else where or ditch it?
Thats one of the reasons people tend to buy return flow coolers so it uses the stock pipes in the engine bay.
I did it becuase i went high mount and FFP.... Ill have to locate the washer bottle on the passenger side as the oil cooler has taken up the rest of the space where the washer bottle was....
next problem?
where to run the boost line? if thats what it is?
the stock pipe that feeds into the intake had a nipple but nothing on the new one.
where do i fit it?
do i put a barb into the silicone joiner from the cold side where it meets the stock intake pipe?
i know this a noob question but i gota learn some how
cheers
yes i saw ur post. the original nipple was on the cold side near the intake pipe.
thats why i asked.
so would it be better to move it to the hot side near the compressor outlet or just put ib back where the original was?
got it finished... yew!
next time i will spend the dollars on a proper r34 kit, there were endless issues with the piping.
i replaced all the silicone joiners that were supplied as they were all to short or the wrong angle.
car has never driven so nice, its amazing how much more response it has with the FMIC and 3" turbo back exhaust.
cheers boys
Why do all piping kits come in 3 piece only? Does anyone know of an RB25 kit that has the turbo to intercooler pipe included?
89CAL that is a very nice setup you have. Good well done :)
The hot side pipe that comes of the turbo compressor and fits onto the 'cooler, I understand that there is only one hot side pipe that goes half way.
So basically what I am after is a inter cooler piping kit that goes from throttle body to turbo. I am running a GT3037S
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
    • This coupled with 6-9 speed autos with ridiculously short gearing is why these modern shitbox cars always seem so fast off the line. If it wasn't for those things, Raptors would not seem fast. The problem we have is there is a driveability gap between a more gentle take off and a wheelspinning sideways launch. The difference between ankle flex required to achieve one and ankle flex required to achieve the other is about 0.5°.
    • Yeah I think I'm also with the opposite here. It's 'hard to keep up with traffic' because in the real world I'm accelerating with 15% throttle and they are pinning it. It feels like I'm being an overt dickhead at anything above 15% throttle, so the car sounds like I'm being an overt dickhead to keep up with/get ahead of traffic when I'm really just trying to drive with traffic. There would be no issue 'keeping up with traffic' if we used the same level of throttle input/aggression to drive around. People really do just drive around with their foot nearly pinned in econoboxes.
    • To be fair it's the other way around. 300kw is boring in a modern Golf or BMW. They are so competent / well-engineered / devoid of emotion that you have to go stupid fast to feel anything. Whereas the <300kw RB still makes all the right noises and it feels good to drive. Can pull off at the lights with the turbo whooshing and the blow-off pssshing and feel like the coolest kid on the block. Just don't look to the side where you'll see the bored housewifes in their shitbox Yaris/Corolla/Camry that kept up because you didn't go fast at all
    • 300kW is so boring in a Skyline, you'll get spanked by someone's mum's Golf with Alibaba pipes, and an email tune.
