Hi, I've got a C33 Laurel with a blown RB25DET (R32 I believe) it has a nistune and some other mods already. I have a chance to get a wrecked A31 Laurel Altima with an RB24S cheap. Will it be fine to use that block? I'm planning to get an RB30 from oz later on so it's just a temporary thing. Thanks
https://www.sau.com.au/forums/topic/420839-rb24-block-in-laurel/
Weren't the factory RB24s SOHC and carbie?
Probably don't need to tell you, but be aware that the RB24 is actually that little bit smaller capacity than the 25 (courtesy of the RB20 crank) so you will need to do a little tuning afterwards.
RB24s actually use RB25/26 cranks so they are not actually using an RB20 crank and have the same stroke. They cant run the same bore so at 81-83mm bores thats where you lose the displacement
The block is notionally the same as an RB25, so, yeah, it should be OK to use. Depends on what you mean by "use". Are you going to transplant the RB25 head onto it?
By the way, your RB25 is not from an R32 (originally). They had RB20, so your engine is probably from an R33.
R32s did come with RB25s. They didnt have VCS and were NA with visually identical manifolds to an RB20 so ...
Also, RB25s head wont be able to be used on an RB24 bottom end. Not without loads of custom work so not going to happen so need to be RB20 based heads
Roy, No.
The RB24S is a factory single cam (basically RB30 head) RB25 block with RB20 crank. We are not talking about RB24s made by stroking RB20 blocks with RB25 cranks.
Also, R32s did not come with RB25 turbos, as per the engine being discussed in this thread.
Edited by GTSBoy
Are you sure about the DNA of the engine. SOme lads in Singapore and Malaysia ran them in their drift scene and looking at them in KL (around Puchong) they told me they were RB20Es with different internals, not RB30Es?
And with a bitsa car there is a good chance its an NA R32 RB25 that has been turbo'd due to loom compatability etc
This from Wikipedia
RB24S
Nissan RB24S engine, Carburettor, SOHC, used in the Latin American market Laurel Altima A31 (an export market name for the A31 Cefiro)
This is a very rare engine, as it was not produced for the Japanese domestic market. These were fitted to some left hand drive Nissan Cefiros exported from Japan new. Mechanically, the RB24S combines an RB30E head, RB25DE/DET block and RB20DE/DET crank with 34 mm height pistons. The resulting 86.0 mm bore and 69.7 mm stroke combined to form a 2,428 cc inline-six engine.
This engine used carburettors instead of the Nissan ECCS fuel injection system. It is able to rev harder than the RB25DE/DET (as it has the same stroke as the RB20DE/DET) as well as being almost the same displacement as the RB25DE/DET. A common modification is to fit a twin cam head from other RB series motors while retaining the carburettor set-up. The standard single cam form produced 141 PS at 5,000 rpm and 20.1 kgf·m (197 N·m) of torque at 3,000 rpm.
Yeh, will be interesting to know. What the guy was telling me made sense as the RB25 didnt really spring up in any Nissans until the R32 GTS25 which was a mid cycle thing from something like 92.
So means that Nissan were using the RB25 block in a car before the R32 in a late 80s export market car. Be interesting to know what sump is on them as I guess the RB26 was around so that is closer to RB25 family of blocks!?!??!
Yeah. It's always been a bit of a conundrum. The only problem with the alternative path to RB24 is that it really takes an RB26 crank and a generous overbore to get it out of an RB20 block, and I don't see Nissan playing those games.
One thing to keep in mind....The A31 ran until 1994. It would have been easy for these RB24Ss to only turn up in the latter couple of years of the run.
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
