I have a R33 GTS-T and am currently looking at the 2 and link of Alcon front and rears (365 front and 350 rear). The car is now 100% used for racing and sprints.
I am a real noob when it comes to this stuff.
Will these fit under my P1 racing 17x8 rims with a 22 offset? I am also looking to buy a couple set of Enkei's rims in 17x9 and am unsure of what offset I will need to fit these brakes and the car without cutting or flaring the guards.
Highly likely that it wouldn't fit
P1 racing will barely fit GTR brembos, they dont have much brake clearance so i'm fairly certain they wouldnt house the alcons
Thanks, I will do some more research and use the cut out template to see if the 343mm will clear the P1's. I am looking at keeping the 17x8 on slicks for transport and sprints and use the 17x9 on R comp tyres (rules are rules) for racing.
So you are in Melb? So how many track days are you seriously going to be doing every year? If its 2-3 then that is very different to 7-8. Places like Winton are far easier on brakes than Sandown and Calder...are you going to do Sprints or just drive days?
What are you running in the way of pads and fluid now?
Thanks Roy. I am just getting a feel for my setup but my intention is to do at least 10 a year. its a full weight if not heavier with the sound proofing (showing my age) and is currently on a very conservative tune of 340kw which I will be probably push above 400 as I play with it. But even at this level I am getting brake fade when pushing it through the twisties especially downhill. So I could imagine my first trackday will be a disaster. I am happy to take your previous advice and give it a go on standard calipers and your recommended rotors and pads. No sure on the current rotors and pads but can't see them lasting at track temps. don't care really about squeal or dust but wouldn't want no streetable performance as i do use it as a daily when I am in the mood. Thanks
I am using a set of 330mm x 32mm 8 pot D2s on the front of my 1800kg Stagea with 17 x 9 TE37s and they pull up fine with no drama time after time from 250km/hr on the back straight and about 230km/hr on the front straight at Pukekohe. have also used them at Hampton Downs, Taupo and Manfield circuits. I just have GTR 2 pots on the rear, a GTR Master Cylinder braided lines and Motul RB600 fluid. Would think that would be fine for a slightly lighter GTR.
I'm running 34 sumitomos on my 300z. I've had dramas with pulling up, glazing the front rotors.
I have a pair of F40's with custom 2 piece rotors but it's for my A70.
My plan is to utilise what's there already. The bias is good. I hit up GSL rally sport and bought a front and rear slotted set and 1ARM pads.
It was really cheap hence why I jumped on them. Because the pads are fairly soft I'll be going through more pads than rotors so it's economical. Also running high temp fluid.
I'll be running some ducting to the front and see how I go.
Like others said maximise what you have already. Don't go project mu rotors... WAYYYY to $$$
You could get ones made up for less than that.
Yeh, it varies so much car to car and person to person. It woudl nto be strange to have trouble on street but not a track. Depending on the roads and the tracks etc. But on a track like PI and Winton there is only really one or two stops that rqequire you to brake for more than 3 seconds...on the road you often cant carry the corner speed you do on the track so need to brake more frequently for longer periods without the high speed bits between that really gets the cool air flowing,
If the thing is borderline on the street though than I expect you are right and you will struggle on a track like Sandown. Places like Winton and I suspect you will be ok, well at least a lot closer to ok.
Frankly, I would throw a set of pads and good fluid at your current setup for your first few track days. Minimal cost and will give you a chance to just get out there and see what you like re feel in brakes with a different pad.
Having had numerous setups on my car and I can tell you about 90% of brake feel and performance is the pad. I suggest something like a Hawk DTC-70s...high temp race pads that you can get cheaply through the US for Brembo equipped 350Zs....you will most likely get a soft pedal from boiling fluid than fade from over cooking pads and rotor temps. So just take an extra bottle of fluid to the track and give it a light flush every session once things have cooled down.
Since you need to change pads anyway to start doing track work than thats a sub $500 solution to getting out there and being able to enjoy the car and get a feel for just what brakes you are going to need. You could find the money saved on brakes could be far better spent on suspension or tyres
Yeh its odd. I have never asked the question. Perhaps ring Project mu distributer and ask why their R34 and brembo equipped 380Z pad numbers are different.
But they are the same pad shape so go with whatever is cheapest...which is why I recommended the 350Z stuff. I ran 350Z DS3000s with the R33 GTR setup I briefly ran
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
