Hah Matty she is all good now. Just needed to cool down
I guess spending half the pass at 5-7k made her get a little warm :P
Good fun and all below the speed limit cause damn that was slippery
  • Replies 62
Posted Images
Had drama's with the camera. Something happened to the card & it has a bunch of corrupted files... so lost a bunch of photos.
Tried recover them, got some... Then, Photoshop wants a serial number so I had to grab a something free to resize them.
Free software goes "we can make your photos look more awesome!" so I said yes... Turns out over saturation is what people think is awesome.
These are the only photo's i managed to recover.
looked like you were having a lot of fun from where I was sitting :)
Can the couple who were enquiring about a V-Spec II yesterday please email me on
[email protected] ???
Meanwhile, I'm very much enjoying the pics.
The BMW respectably followed a GT-R all the way up the mountainside > no slipping either
Thanks mate. I believe they are around 380mm at the front. Discs are AP, and yep calipers are Brembo GT 8 piston front 4 rear. Can't sing the praises of good brakes enough, especially on a day like today!
Are the front rotors 36mm thick? Can the calipers support that wide of a disc? If you dont mind me asking, where did you source them?
I only ask as i am upgrading my brake very shortly and am weighing up my options.
If you are looking to pick up a bargain upgrade I've got a big Alcon brake kit for sale Damo? :thumbsup:
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
