Just an exhaust & Impul ECU
That's pretty good.13.9. I believe that's what Lamborghini Diablo's did. Not a shabby time.
How do you take off? No burnout. Go around the water.Then foot on break, rev's, foot off break go?
I've never had an auto before but the car doesn't seem to hold any revs when I try this and bogs down hard when I try to launch.
Am I missing something? The computer seems to kill the revs rather than just hold them up??
Do you know the performance gain from the Impul and exphaust? I ask as the car I nearly bought had that exact same thing. An Impul ECU and an exhaust. I had no idea the power increase over a standard Stagea it might have had.
Also, 20Valve. Did you have a 20Valve 4AGE?
Matt, does your car have the brake cut mod done? If so, it will just be the stall converter being slightly too small for the turbo now it's highflowed. Some of this lag can be tuned out with the Emanage Ultimate.
Burnout or not made no difference, there's no wheelspin on takeoff regardless. And yeah, just stall it up on the line & get off the brake when you see a green light. lol
Sounds like brake cut switch isnt on if you cant get the revs up, maybe.
The exhaust gave the most noticable difference, but i dont have any before & after figures. I'll line up someone with just an exhaust one day & see what the actual difference is to compare what the Impul is doing for me.
And yes, had a 20v AE86 years & years ago. :D
You has pics of Hachi?
My workshop owning mate just offloaded his 20V headed, GZE bottom ended AE86 a little while ago; was good for an 11.1 quarter! 330mm Wilwoods and a tonne of fun bits.
Very lively to drive.
what time you heading out might come down to watch and a yarn :yes:
From early. Can't stand queuing up in the scruitineers line.
Origin is on. No chance
No fks given. Hopefully it knocks the crowd on the head. Moar runs.
Slow.
Like the results.
Ok. PNM35 RX light mods cat back exhaust, plenum top, transgo kit, otherwise stock
14.9@93mph.
Did three runs. All within 0.01 of each other. Anyway, had some fun. 60 foot was the same as with the turbo kit. ET was 1.1 sec slower.
Slow.
Like the results.
14.9@93mph.
. Impressive top speed
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
